TV will not let us manually put in channels - Televison & Video
    Champion:
  • 209 Answers
Do you mean using the TV or cable box remote? If you are using a cable box remote, then the TV remote control may not work due to having the TV on one specific channel so the cable box remote will work. Or, if just using a TV remote with no cable box remote, then the keys on the remote could be overused and pressing them might not be allowing the key(s) to come in contact with what the key(s) are suppose to come in contact with on the circuit board below the key(s).
Posted on Dec 23, 2016
I have a VIZIO E552VL TV hooked up to an Over the Air Antenna and want to MANUALY put in channels NOT AUTO SCAN
Not sure if your TV is digital or analog, but I think an analog TV does not have the ability to perform auto scan, so you may be able to manually input the channels. As a kid, my dad installed a rotary antenna, and as it rotated and TV pictures displayed on the screen, dad noted the specific spot on the rotary unit; and every time we turned the set on, we just pointed the arrow on the dial on the unit to where dad noted what the channel number was on the unit, and the antenna turned toward that direction, and the pictured appeared on the screen.
Nov 16, 2014 | Vizio E552VL 55" 1080p 120Hz LCD HDTV
Finding the AV Channel on a TV
There may not be one on your TV. If your TV has audio and video input jacks then keep changing channels going from high channels to lower ones. When you get to Channel 2 then the next one down should be AV. If your TV doesn't have the A/V input jacks, then you'll need a modulator. This will take the audio and video outputs of the DVD player and put them on TV channel 3 or 4 and insert it into the antenna connection of the tv.
Jan 23, 2014 | Televison & Video
Cannot get it to change the channel to recieve cable from the cable box. it says it is on channel 2.1
If you are using the channel up and down buttons, sometimes it will skip channels. Try manually putting in 03 using the remote to change to channel 3. Also make sure that in the TV menu you have the TV set to Cable instead of Antenna.
Jan 13, 2011 | Sharp LC-19SB14U 19 in. LCD TV
How do i put it on channel three manually?
If the remote to your box can be paired with your tv then you should be able to fix this problem simply by pairing digi remote with tv and while in tv mode on remote, hit the input button. That should change tv back to cable/antenna setting so that you may access channel 3. Hope this was helpful.
Jan 27, 2010 | Symphonic T19WF 19" TV
I do not have the manual for my JVC TV. Having problems setting the proper channel number to get my Directv stations
Use a generic universal remote. Program the remote to your JVC tv. Use the newly programmed remote to put your JVC tv on channel 3 (or 4) or the appropriate channel for Direct TV.
Aug 13, 2009 | Televison & Video
Channel changing Problem
when you hit auto channel the tv  start to check the signal incoming
and put in memory the good signal - i think your tv is functioning
you have to use the channel on manual for   put in memoty what
you need- delfo
Mar 20, 2008 | RCA F32718 32" TV
Getting it plugged in right to work with tv set
you dont put it on channel 3 like a vcr. you put it on video input like you would when playing a game.
Mar 10, 2008 | TruTech TT1620 DVD Recorder
TV not storing vcr channel
most newer tv's wont store the channels if the channel isn't always putting out a signal. not much you can do about it
Oct 31, 2007 | Televison & Video
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
