Question about Honeywell Heating & Cooling
Owner's manual for Honeywell heater/radiator(oil,combustible)style:HZ717 SKU:09292697171
  • yadayada
    yadayada Dec 20, 2016
    What is wrong with it?
Tip-over switch location
It will be inline with the power entering, meaning probably by the thermal overload, it may not be equipped with that , but rely on a thermal overload as the oil units surface temps are no way near the point of combustion if it does touch aything as curtains or rugs etc.
Feb 24, 2012 | Honeywell HZ-709 Oil Filled Radiator...
I have a oil filled rad style electric heat ,which is leaking oil can it be fixed? If so how.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman10
Dec 19, 2010 | Honeywell HZ-709 Oil Filled Radiator...
Where can I download the owners manual?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the owners manual for your model. If you need anything else, let me know.
Feb 20, 2010 | Honeywell HZ-709 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Heating & Cooling Logo
29 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
