Question about Home
Cleaned parts on my water softener and noticed the brine line screen was missing.OK,just install one,or might I have a problem? Also noticed a small drip from the piston push rod.
Fleck 2510 w/ 1650 brine system
bearsfan7538
  • 119 Answers
SOURCE: Not getting soft water.
You need to remove the venturi valve and clean it. This part is usually found under a round plastic cap that unscrews remember to put softner on bypass or turn off water first
Posted on Nov 15, 2009
  • 569 Answers
SOURCE: Kinetico Water Softening Unit has brine tank drainage problem
This sounds like the resin cylinder is perforated or connections at the top are leaking. The brine tank should only have a little water in the bottom - if it is full of water (maybe even up to the overflow?) then you will need to replace the resin cylinder or fix a leaky connection to it.
Is the water in the brine tank 'rusty'?
Posted on Feb 21, 2010
Testimonial: "Thank you so much. My husband is quite handy but never having dealt with water softener we were looking for some advice. We certainly appreciate it!"
  • 15 Answers
SOURCE: Have a fleck 5600 water
The 12 day wheel is used primarily so that the unit does NOT regenerate on the same day of the week, every week.
There is a 7 day wheel available for this valve so if you irrigate on specific days, and you need it to cycle on specific days, you have the ability to do it without the softener cycling at the same time as watering schedule.
Posted on Dec 17, 2010
  • 15 Answers
SOURCE: My Fleck 5600 Economizer runs
There could be an o-ring missing, which is located in the brine piston bore, this is the little piston that resembles a spark plug.
  • 15 Answers
SOURCE: The gears are jammimg when it gets to the brine
Most likely it's NOT the motor...If you can remove the entire timer box, or "Power Head", you will see that the main dial is easy to turn..remember..." CLOCKWISE ONLY!!!!"...the problem is more likely the main piston the is locking up in the valve bore, you can find parts for this valve online...you will need a new main piston, a brine piston (the smaller one on the right) and a set of spacers and seals.
Posted on Dec 23, 2010
Kenmore Water Softener does not advance through cycles
You can send to the company for repair too ! If it sill under warrenty to fix it and aslo don't try the step anymore it might cause some parts damage that the service provider my charge you more.
Dec 09, 2013 | Washing Machines
Tip
Water softener salt bridging
One of the most frequent problems with water softening systems is salt bridging in the salt/brine tank. There are several reasons for salt bridging to occur. This generally occurs when pellet type salts or potassium chloride is used to regenerate the water softening system. Pellet type salts contain binding agents that in turn give the salt a very starchy consistency when wet. As water evaporates in the brine tank the pellet salts partially dissolve, bind together and form a "salt bridge" in the tank. Potassium chloride (Kcl) acts in the same way. Excess water in the salt tank, with high salt levels, can also cause salt bridging. Improper softener brining and lack of proper brine refill will cause bridging to occur as well.
What is the best way to alleviate these problems?
1. When using pellet type salts or potassium chloride only keep the salt tank about 1/2 full. This prevents too much compaction of the salts and helps to prevent bridging. When using potassium chloride get the salt tank off the floor on a wooden platform to prevent wicking of moisture from concrete floors.
2. Use a high grade of salt. Most water treatment dealers use either
DuraCube or HardiCube water softener salts produced by Cargill Corp.
Cargill has a link to find dealers in your area.
https://saltapps.cargill.com/cargillsalt/product_locator_new.asp
Solar Salt is another option as the crystal structure is very hard and virtually impossible to bridge. This is also available from many Cargill salt dealers and in stores.
3. Let the salt tank run down to 80-100lbs of salt or potassium a couple times per year to help prevent buildup of dissolved salts in brine tank.
4. Yearly maintenance of the water treatment system helps also. Restrictions in the brining system (injector/eductor assembly) caused by sediment and oxidized iron buildup cause improper brining and too much water in salt tank during refill. Have this assembly cleaned yearly. Have the water tested to see if the water chemistry or usage have changed and adjustments to the system are necessary.
5. Avoid using rock salts to prevent buildup of sediment in brine tank (which causes service problems).
Practice these tips and you will have fewer water softener problems and more consistent quality softened water.
I wish you good water!
H2O Services
on May 17, 2011 | Water Dispensing & Filtration
Kenmore Water Softeners Model 625388270 Serial 12756 - Water above the salt level. I have cleaned the venture nozzle. Did not help
On this model, the problem is usually the rotor and rotor seal. When they wear, they don't let the softener create a vacuum to pull the brine water from the tank. This is a fairly complex repair. I don't have a service manual for you. The parts are available from Sears. I know this is not much help, but I've worked on hundreds of these and this is the problem 98% of the time.
Aug 05, 2013 | Kenmore 420 Series Water Softener
It looks that water is leaking from the - Culligan water softner
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it.
RJ
Jun 14, 2010 | Culligan Sediment Water Filter
Have an rainsoft Q10 classic apollo softner that does not draw brine. Ran a wire thru the brine injecter tube and it appeared to be clear of obstruction. Drained tri-guard glass did startcycle and redrew...
You most likely have a slight leak in the brine line. This is the most common failure on a water softener. A slight leak will allow air to enter during brine draw, breaking the vacuum. it doesn't take much of leak, in fact it can be small enough that water does not leak out during brine refill but it will not draw brine. Check the compression fittings at the brine tank and the softener valve. disassemble the connection, cut back the tubing and reconnect. Other things to look for are low water pressure, the unit requires 25 psi minimum during regeneration. Also make sure the drain line is not restricted and the maximum head on the drain is 4' over the softener.
Mar 16, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
FILM ON GLASSES, IS THIS HARD WATER, MIGHT BE MY WATER SOFTENER??
Film on the glasses may be a sign that the softener is not working correctly. It may sound silly but check the obvious first, is there salt in the softener brine tank? if not fill it up, allow it to sit for at least 8 hours then manually regenerate the unit. Also check the power to the softener. Check to make sure the bypass is not open. If this stuff is ok then have a local reputable water treatment company come out and test the water hardness to make sure the softener is working correctly. If they say it is not working check the brine draw tubing. The most common failure is from a slight leak in the brine draw tubing which keeps the unit from regenerating effectively. During the brine draw phase of regeneration (2nd step) the softener should draw all the water from the brine tank. Repair or replace the tubing as needed.
Mar 10, 2010 | Whirlpool 24 in. GU980SCG Built-in...
Feb 11, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softner problem, does not refill water to brine tank
There is .25 gpm flow restrictor in the top of the float assembly, It may have sediment in it. Unscrew the cap on float top and check the restrictor. When you hook it back up run the system to refill (last cycle) hold the float stem down until all the air is purged from float assembly and see if that works. Also the float ball (foam) may have slipped top too far and is shutting off prematurely. If this does not work it is in the valve which has small pistons, diaphrams and springs to control the cycles. Each cycle also has a solenoid which makes these components work. You will not find a service manual for the Mark 50 valves. They are obsolete unfortunately and parts are no longer available. This valve was made for nearly 40 years and was the hallmark of the Culligan line.
RJ
Jan 03, 2010 | Culligan Sediment Water Filter Heavy Duty
I inherited a water softener system with the house - I do not have any manual or cannot see the name anywhere. It worked fine for 4 years and now it's stopped and do not know what to do? We added the...
There are a number of things that it could be. The main problem is that the softner is not sucking the brine into the tank. It still ran water into you tank till the safety shutoff stopped it. This made all the salt turn into a big lump. You will need to find out why the unit does not have suction when it is in the "brine and rinse" mode. Probably either the float in the brine tank is stuck or there is dirt in the screen at the top of the hose out of the brine tank that is stopping the brine from being sucked up the hose. First empty the tank and then you can see what the unit is doing from there.
Nov 16, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
GE SmartWater Softener GNSF35ZO1
I am not familiar with your specific model of softener, but generally speaking, adding water to the brine tank is the last step of the regeneration process. This way the water can soak the salt until the next regeneration is called. Then, as you have determined, the valve does reverse direction and draws the brine solution through the resin.
There are other steps involved in regeneration, like back-washing and packing the resin, but you are mostly correct.
Hope this helps,
Kermit
Aug 15, 2008 | Kitchen Appliances - Others
Home Logo
83 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
