Question about Intermatic Electrical Supplies
Isthere a remote light switch for intermatic t10004r
    Top Expert:
  • Intermatic Master
  • 80,407 Answers
Contact Radio Shack for this part.
Posted on Dec 20, 2016
Intermatic t10004rt3 pool timer cycles a loud hum/buzz noise like bad contacts or relay
T10004R control center has one T104 240V timer, with extra space for another timer or freeze control etc.
You can clean up the timer and replace clock motor to stop most noises.
The T104M (M for mechanism-only, snaps into the control center enclosure.
The T104 also snaps out of enclosure using thumb spring located top inside box.
Take image of wires before disconnecting from timer.
The T104 is identical to WH40, same parts, same trippers, same appearance, except with different override lever.
Here are photos of WH40 showing how to take apart timer and clean it, also with links identifying replacement parts:
http://waterheatertimer.org/Photos-of-WH40-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
If you need to replace timer, it is cheaper to buy the ordinary T104 that comes inside a box and can be snapped out, instead of buying T104M (M for mechanism-only)
Gene
h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Apr 10, 2014 | Intermatic Hardware & Accessories
How can i set up the time of the pool light in the a box model T10004R?
Typical T1000R series pool control center has space for 2 timers, and comes with one T104M 240Volt timer. Additional timer mechanism can be added to control lights, etc.
Copy following link for setting T104 series Intermatic clock, with link to wiring diagrams.
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
Intermatic pool timers are extremely durable and versatile, and modular so they can be repaired almost indefinitely using ez-to-locate parts
Additional link for replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#T100
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Oct 28, 2012 | Intermatic T10004R - Pool-Spa Mechanical...
Timer will not turn off
Question posted under Intermatic T10004R pool control center.
If installation worked before:
Might be worn 156T1978A tripper.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
If this is new installation:
Might be wired incorrectly. Wires from breaker confused with wires from Load.
http://waterheatertimer.org/images/T104-wire-from-breaker-600.jpg
Sep 29, 2012 | Intermatic T10004R - Pool-Spa Mechanical...
How to wire model t10004 control panel intermatic inc? I am just looking for a picture of the wiring diagram. All I need to do is hook up a the wiring for the light.
T10004 control panel has 240V T104 timing mechanism.
1) You can use T104 timer to control 120volt light if you have a neutral wire:
http://waterheatertimer.org/images/T-104-control-120V-Load3-45.jpg
2) Lights are usually 120Volts with black hot wire and white neutral wire.
3) T104 timer is 240Volts with two hot wires L1 and L2 that can be white-black wires or red-black wires.
4) Open following link to see basic 120V and 240V circuits.
http://waterheatertimer.org/B220C.html
5) Open following link for T104 wiring options
Jul 17, 2011 | Intermatic T10004R - Pool-Spa Mechanical...
Have a intermatic t10004r pool controller box. pool light not working. box is only 1.5 yrs. old only used light 4 times all brand new 1.5 yrs ago
T10004R comes supplied with one 240Volt T104M timer mechanism.
T104 mechanism can be tested to see where problem is located.
Open following link for troubleshoot checklist to see where problem is located.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Recommend standing on dry surface and using same precautions when working inside circuit breaker box.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 03, 2011 | Intermatic T10004R - Pool-Spa Mechanical...
I have 2 black wires at home one that usually connects to ON side of the switch and other black connects that OFF side (bottom) of the switch.. I'm trying to use Intermatics Touch CA3000 switch - but...
One of the blacks is a hot that connects to the black wire on the switch. The other black wire is the switch leg (to the light) that connects to the blue wire. The yellow wire on the switch is not connected in a single pole application. If you don't know which black wire is hot you'll need a volt tester.
The CA3000 is then controlled with the CA5500BR Handheld Remote with Smart Base.
http://fmal.info/intermatic-ca5500br-intouch-wireless-hand-held-remote-controller-and-smartbase-kit
Jan 15, 2011 | Intermatic CA3000 InTouch Wireless...
Utilitech self adjusting wall timer used in place of one three-way switch of two that control a light. When hooked up as suggested (wire color to wire color) the light only turns on briefly when the second...
Your INTERMATIC ST01C Digital In-Wall Timer is
not compatible with a REGULAR three-way switch
configuration...
((besides being a rather poor timer ( my opinion ))).
Following WIRE colors is TOTALLY INCORRECT...
(and dangerous).
The only way you can "use" this switch is to OVER-RIDE
both 3 way switches...
BUT YOU SERIOUSLY
NEED to KNOW WHAT you are doing...!!
I would seriously recommend you consider "SMART"
switches... Check out home automation or
SMART-HOME ... Insteon... X10 or even
LEVITON's remote capable switches...
Each end of a "3-way" circuit work closely together...
are HARD-WIRED and CANNOT be easily, conveniently
or safely overridden (in my opinion).
Hope this helps...
Naaah...
Intermatic KM2STU 1G 1 Gang SPDT 24 Hour Mechanical Timer Amazon com
Nope...!!
Intermatic ST01 Series Easy Setting Manual Programming Fixed Time
One (apple) possibility (ALEXA enabled devices)
Eve Light Switch Connected Wall Switch with Apple HomeKit technology for...
Another remote
(X10 technology (less proprietary & ALEXA compatible))
https://www.amazon.com/s/ref=nb_sb_ss_i_3_11?url=search-alias%3Dtools&field-keywords=insteon+hub+pro+homekit&sprefix=insteon+hub%2Ctools%2C276&crid=3QBCXIC1GUTKD&rh=n%3A228013%2Ck%3Ainsteon+hub+pro+homekit
Hope this inspires...
Carnac the Magnificent
Jan 10, 2018 | Intermatic Inc. ST01C Digital In-Wall...
Bought an intermatic model EI600 wall switch timer to use with gfl outsidelights. black green, blue and red wires from the back. Went black to black, green to ground, red tored and blue to white in...
That is a three way timer. There is no wire that the white wire gets hooked to. The black is the hot, the blue sends power to the device, and the red goes to a switch that connects it to the blue wire essentially. Here is a PDF of the directions, including wiring diagrams.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei600c%20-%20english.ashx
Mar 06, 2010 | Intermatic EI600WC - In-Wall Decorator...
Intermatic t10004 control panel trips the circuit breaker
That circuit breaker is letting you know that you've got a problem in the electrical wiring.... What's next is to turn the power off to BOTH legs of the breaker.
Begin by physically inspecting all the connections in the timer box, and at the breaker and all the way to the pump motor. Make sure all connections are dry, and there's no water in any of the conduits...this will cause a short circuit and trip the breaker. If there's any bare power leg wires touching a grounding point , this can cause the breaker to trip. Lastly check the motor on the pump; on the motor end, there should be a cap you can remove and use a crescent wrench to make sure the motor shaft is moving freely. It could be jammed with debris....this happens around my pool often because I'm surrounded by trees with needles. If the motor cannot turn freely, this will cause the breaker to blow... I'm pretty sure that your timer isn't the issue... Please let me know what you find out.
Nov 19, 2009 | Intermatic T10004R - Pool-Spa Mechanical...
Electrical Supplies Logo
152 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
