Question about Winter Sports
1990 ski doo mach 1
My 1990 ski doo has no pick up power. It acted like it cleared up and then went back to actimg bogged down again? Any ideas?
    Top Expert:
  • 78,267 Answers
You have dirt in the carburetor jets and or passages, clean the fuel tank and rebuild the carb.
Posted on Dec 20, 2016
Where do i get a tool to adjust belt tension on a 1989 ski-doo mach-1
COPY AND PASTES THIS ADDRESS (http://www.vintagesnow.com/Ski-Doo_files/1989_SM.pdf) INTO YOUR BROWSER'S ADDRESS WINDOW AND DOWNLOAD THE EXCELLENT MANUAL FOR YOUR VINTAGE SKI-DOO. READ IN DETAIL THE DISCUSSION ON BELT TENSION
Dec 29, 2017 | Cars & Trucks
How do I remove the battery from a 2014 Ski Doo 900 ace snowmobile?
About 26,400 results (0.92 seconds) Search Results
    Brp Expert Tips For Summer Snowmobile Storage ' Ski-Doo ...
    xteam.ski-doo.com/en.../brp-expert-tips-for-summer-snowmobile-storag...
    Apr 4, 2013 - BRP Expert Tips for Summer Snowmobile Storage ... If you have a 1200 4-TEC or ACE 600, change the engine oil and filter. ... SnowTech's First Impressions of the ACE 900 Engine .... September 2014 (4); August 2014 (1); July 2014 (1); April 2014(2); March 2014 (6); February 2014 (14); January 2014 (5) ...
    First oil change opinions - 900 ACE 4-Stroke Models - DOOTalk ...
    www.dootalk.com/forums/topic/671977-first-oil-change-opinions/
    Dec 15, 2013 - Page 1 of 4 - First oil change opinions - posted in 900 ACE 4-Stroke ... suppose to be easier on the 2014 , different battery bracket ? or you can ... 900 Ace Summarization ??? - 900 ACE 4-Stroke Models
    Apr 1, 2014
    900 ACE no power at outlet - GPS Talk
    Jan 15, 2014
    2013 Skandic WT 600 ACE - Skandic / Expedition
    Dec 22, 2012
    Battery Removal - Skandic / Expedition
    Apr 12, 2012
    More results from www.dootalk.com
Jan 24, 2016 | Ski-Doo 2014 GSX LE 900 ACE
Wiring diagram for a 1990 ski doo safrai le
Request a manual directly from Ski Doo.
Jan 21, 2015 | Winter Sports
How to winterize a 600 e-tec 2012 ski doo expedition
your manual under the seat should explain how...
Manual says press high/low beam switch rapidly but what they don't say is, which is very important, don't press it so much that it clicks.
As in don't let the hi/lo beam switch click like it normally does when switching from hi to low?
I just fogged both of my etecs for the first time half an hour ago. I clicked the hi/low beam switch all the way rapidly and the "PUSH S" message never showed up. So I went back and switched it VERY RAPIDLY while holding the "S" button and it worked. As soon as "PUSH S" showed up on the display, I pushed the "S" button down until the "OIL" message popped up and it fogged and shut downicon1.png on que.
I friend of mine said he could never get his etec to self-fog. I think he wasn't pushing the hi/lo beam switch fasticon1.png enough for it to engage.
Hope this infoicon1.png helps.
May 17, 2014 | Ski-Doo 2012 Expedition SE 600 H.O. E-TEC
2009 SUMMIT SKI DOO WILL NOT START
Ski Doo's are known to have BAD KILL SWITCHES
DPM going bad
Dec 24, 2013 | Ski-Doo 2009 Summit Everest 146 800R Power...
Skidoo has no pick-up power
I am assuming that you have checked the following?
Compression
Replaced Spark Plugs
Cleaned the Needles (Making sure you can see through the Center of the Jet
Nov 30, 2013 | Ski-Doo 2006 Mach Z Adrenaline 1000 SDI
Help!! '97 Seadoo GTI, just had the carburetor rebuild, replaced the Rectifier Regulator, replaced the spark plugs and recharged the battery. But the jet ski would only reach 40mph and it would bog down to...
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
Sep 23, 2013 | Sea-Doo US Boating
I have a 1998 ski doo 700 Mach 1 that starts right up and will ride fine for about 5 minutes then will shut right down. It will start right back up again then stall after 2 minutes, and keep doing this....
When the engine overheats, a thermocouple sensor will shut the engine off to protect it from damage. After cooling for a period, you can restart it and run until it overheats again. Check your cooling system ports for clogs and water pump impeller and function.
Jan 22, 2018 | Boating
Winter Sports Logo
325 people viewed this question
Top Winter Sports Experts
vtrktrmn
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
