My prop stopped spinning I looked all over YouTube and can't find out how to fix it
  • Washing Mach... Master
  • 17,431 Answers
When the agitator of a top loader stops, it is usually the clutch. It is not a job for a home consumer.
Posted on Dec 20, 2016
I have a Global Drone X183 upon take off the cone shaped prop cover comes of so the propeller to come off.There appears to be no way to tighten the cover as it has no threads.Please help me.John
You have put the incorrect prop on. You must put a prop that is intended to spin the direction of the motor you are affixing it to. Look at the way the blades are angled, then use a prop with the blades angled the oppostie direction for that motor. The correct prop is likely on one of the other motors, so you would swap those props.
Nov 11, 2017 | CompuStar DroneMobile DR2000 Smartphone...
The CD player will rotate but won't play as though it's not reading.
How to Fix your CD Player ' Librarian in Black Blog - Sarah ...
librarianinblack.net/librarianinblack/how_to_fix_your/
Well, if I was a junk pack-rat and still had all the CD players I've thrown away because they stopped ... my portable cd player lens looks to be scarched how can i fix its ... my 3 disk memorex cd player won't play any thing. it was working fine and then allof a sudden it stopped on me it won't even spin the cd to try to read.
No Disc Error, not reading CD error: Repair Sony CFD 112 ...
? 11:35
https://www.youtube.com/watch?v=iEG_u0ogjZI
Jul 23, 2013 - Uploaded by 1000uf
How to troubleshoot and repair CD player not reading disc, table of content (TOC), ... +DeathlyHall0w It's ...
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
If you move the boombox with the audio CD player will it slip, with this model? ... I cannot buy a new boom box ...
Why won't my disks spin? - GameFAQs
Dec 22, 2015 | Audio Players & Recorders
The fan has stopped working the receiver is not working. What component has to be replaced in the receiver I.E Diode,capacitor etc.
FAN STOPPED WORKING? Fix it! - YouTube
? 7:40
https://www.youtube.com/watch?v=5WOdTVz2NlY
Jul 11, 2010 - Uploaded by Generatorblue Generator blues
Now it has to be replaced with same rated replacement. Brand makes no differenc3. Just rating. And then fan ...
Electric fan repair: Blades don't spin - YouTube
? 1:20
https://www.youtube.com/watch?v=RIUtBWJeJDE
Aug 21, 2012 - Uploaded by 1000uf
A simple fix for your fan that doesn't start. ... And also stop. thanks .... Please see my other fan repair video in ...
How to Repair a Ceiling Fan ' HomeTips
Dec 14, 2015 | Dryers
Prop spins when out of water but when i put it in the water it slows down to a slow creep
yes very common, have you hit a rock as some stage or maybe it is wearing out but as soon as some pressure goes on the prop the shaft will spin normally but the prop is now no longer held to the shaft correctly hence your problem. Check it by marking the prop and shaft with a straight line then put it in the water, take out and check your mark they probably wont line up anymore. Solution...get a new prop. I have a different way to get these fixed but it is not recommended I drill a self tapping screw into my props just until it hits the drive shaft then stop just enough pressure to keep to stuck to the drive shaft
Apr 09, 2014 | Minn Kota Riptide St Saltwater 55 Bow...
Motors stop as throttle increases
Spin the props over by hand and see if any are dragging; if they are then that is the problem. Those speed controllers have a safety that stops them if there is resistance on the motor. One other thing it could be is your battery could be bad or not getting charged properly. Good luck.
Mar 24, 2014 | Walkera QR X350 Quadcopter BNF WALQRX350
I have the Air Hogs Helix X4 Stunt Quad Copter and it flys to one side sometimes. One of the propellers will periodically stop. When I turn the throttle off that same propeller stops spinning earlier then...
I have the same problem, two props spins freely when I spin it by hand in switched OFF position. and in ON position, when I turn down the left control to zero they continue to spin while other propellor stops. I know this info is not a solution but if there was a "how to replace motor or propellor" site. maybe I'd find a clue to why the props drag and get it to spin freely like it suppose to be. I could probably put a video together on that topic but if there is already one out there let us know.
Sep 22, 2013 | Spinmaster Air Hogs Helix 360 Helicopter
After a minimal crash the bottom blade is not spinning , but the whole copter is trying to spin.
probably you bent a piece near the shaft and it is stopping the prop from spinning but since the motor is still spinning it still tries to spin the other side of the shaft(the copter)
Dec 21, 2011 | LawlMart iPhone Apps
My boat goes in backwards when i put it in gear and when i put it in reverse it goes forward. what could be the problem?
My guess is you have the wrong prop on your boat. You need to check if it is a right or left prop. Right hand prop will spin clockwise if you are looking at it from the rear.
Sep 12, 2010 | Kitchen Ranges
BOAT WONT MOVE WHEN IN REVERSE
how far below the boat is the propeller? Since the boat is fllat in back, you may need bigger proppeller. Check to make sure it is getting plenty of water flow
Jul 07, 2009 | Light Outboard Motor Boat Bass Fishing...
Trolling motor will not spin with out being turned by hand.
Take the prop off and make sure the pin that goes through the shaft is in place. The prop could also not be sitting on the pin proper.
Nov 29, 2008 | Humminbird 575 Fishfinder
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
