Is it normal for 40' technika to have 2 white lights or lines at top of screen
    Top Expert:
  • Televison & ... Master
  • 80,637 Answers
No you have a problem.
Posted on Dec 20, 2016
2 Suggested Answers
  • 76 Answers
SOURCE: White line runs from bottom of screen to top
This is the rastor that you are seeing - it may be possible to adjust the contrast and brightness to remedy however if you have not enough range in your adjustments and it results in being unable to see a usuable image then you more that likely have a problem with the HT coil which must be repaired/replaced at the shop. This is likely to be "fairly" expensive! I take it this is a CRT TV - if it is an LCD then it would be interesting if the sympton occurs at 740 and 1080.
Posted on Feb 15, 2009
This 40" Technika (for which I bought a sky special offer warranty on line at time of order) has developed two very annoying black horizontal lines permanently across the screen, about 9" apart. Is t
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 16, 2014 | Televison & Video
Technika tv screen goes pink when plugged into laptop movie
try reseting the laptop when the tv is plugged
Apr 24, 2014 | Televison & Video
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
Faulty technika tv
A good way to test if a remote is working is to get a normal phone that has a camera on it.
put the camera option on the phone and point your remote at the camera phone. Press the button you believe to be faulty. whilest looking through the phone. if you see a little white light the button is working fine if not try a few of the other buttons to see if its the hole remote that is at fault.
the way this works is camera phone's dont like IR (infrared) so this will show as a little white light on your camera phone.
if it is the remote you could always buy a sky digibox remote. as the Default code will work your Technika tv. ie volume, channels, power, also the help button will change your source/av on your telly.
Hope this helps
Cheers
Little Dish Fitter
Sep 02, 2009 | Televison & Video
My original nintendo DS has little white lines in the top screen!
Well, if the lines stay on the screen even when the DS is turned off, it means the LCD screen is broken, thus the crystals are flowing and blotching. This means the screen must be repaired, however you don't have to buy a new one.
Nintendo has a page about original DS repairs Here. They also offer certain warranties, I'd see if one applies to your situation. (They also have a more broad repair page Here.)
If you feel like doing the repair yourself, it is apparently very easy and costs about $40 to replace the screen. There are many different repair tutorials online. (I just did a Google search for "DS top screen repairs") Here is one of those sites.
I hope this was of assistance.
May 02, 2009 | Nintendo DS Lite Console
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
PC or monitor, signal problems
your monitor is telling you it's on it's last legs..either that or your compaq has a bad video section. either is more vital than a video cable being loose.
Mar 10, 2008 | Computers & Internet
Top of the screen Picture Problem
sound like you have 1 or a couple of leaky/bad capacitors in the tv's vertical circuit, typically, there sould be 5 to 10 caps. in all, but you just need 1 bad one to cause your problem. good luck.
Mar 13, 2007 | JVC AV-27230 27" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
