Question about Farberware Coffee Makers & Espresso Machines
Need spigot for Farberware coffee urn # L1360, 155C
My spigot leaks, has a nut holding spigot inside the urn. Spigot is black front with square chrome metal on the back end of the front black part.
2 Suggested Answers
SOURCE: Leaking Around Spigot, Coffee Urn
I have a Farberware L1360 with the same problem . If there is water in the pot , in about an hour a nice little puddle forms . It is leaking right where the spigot attaches to the body of the pot. I can see a rubber washer squeezing out around this spot. Maybe It melted?
I think it needs some heat resistant washer to replace it. Farberware co. doesnt really exist anymore. you can barely get parts. If the spigot itself works, mine does. I can't see buying a new one if it just needs a washer. Does anyone know what type of washer would be a good replacement?
Posted on Apr 04, 2008
I misplaced directions on how to tighten the spigot. Need to know, please
Looking at close-ups of the picture, it has a standard type spigot assembly for a glass-walled beverage vessel. There's a spigot on the outside, with a threaded hollow shaft behind it, a soft compliant gasket between it and the glass, the glass, another gasket, and an internal screw. Looking closely at a picture, such as the one here (
Shangri La 320 oz Beverage Dispenser ), you can even see the hex-head on the internal nut. With the container (hopefully) empty, get a medium sized crescent wrench or slip joint pliers, reach in and grab the nut. With the other hand, hold the spigot and make sure it's square (spigot pointing down and not off to the side). Turn the nut until it's firm. Don't over-tighten it - both the pliers and the threads multiply the force on the wall. If it's really loose, tighten first by hand, then another half to 3/4 turn, at most, with the pliers. Add some water and check it doesn't leak, and you're good.
Good Luck!
Nov 06, 2015 | CIRCLEWARE Shangri La Beverage Dispenser
The spigot leaks. It seems the threads on the inner screw-on nut have stripped and we can't get a leak-free spigot. The urn is being used in our staff lunch room at Rain Forest International School in...
if you can get hold of some plumbers ptfe tape then that might fix the problem, dissasemble the spigot and wrap the tape round the stripped threads, then do up tight. a heavy duty filler such as chemical metal would do the trick too.
if you cant get hold of these bits then there is a temporaary fix that might work, dissasemble the spigot and coat the threads with loads of egg white, put it back together and heat it up until the egg cooks, with a bit of luck it will expand enough to seal the joint (this can work on leaking car radiators too).
good luck
Nov 25, 2010 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Need to replace my spigot on my 30 cup revere ware coffee maker because it leaks. Where can I get one to "pop" into that hole so I can pour the coffee out of the pot into the cups.
I have a Westbend 24 cup coffee urn with a leaky faucet. I tried finding areplacement spigot for it but so far no luck. My spigot has a screw in the top that allow for disassembly. It looks to me that if I could get a replacement rubber O-ring I could fix it myself. Does anyone know where I could get this?
Thanks
Kelvin
kelvinlov@gmail.com
Sep 16, 2010 | West Bend (59055) Stainless steel 60-Cup...
We have a large farberware electric percolater
Hello, only a sugestion but most store that sell electrical goods have repair centers or repair personsat their disposal. Try contacting them they may be able to help, you may be able to find a good handyman in your local phone book. I hope thi helps.
Nov 06, 2009 | Cameras
How do you fix a leaking outdoor wall spigot? Even though the handle is turned tightly off there remains a drip. Spigot seems to be all one piece and attached into stucco wall. Is there a way to repair...
Sometimes, depending on the type of the spigot, you can unscrew the valve from inside the spigot. There would be a hex nut immediately under the part where the handle on the valve stem comes out. BE CAREFUL: Outside spigots rarely have independent shut-offs (ie, in order to work on it, you will have to shut off the main water supply). Once you start down this path, you need to be fairly certain there is a replacement available for your type of spigot. If you remove the valve, there is no assurance that you will be able to get the original back in without making the leak worse. Please have an emergency back-up plan in place.
Sep 16, 2009 | Plumbing
Why is water leaking out of spigot lever of coffee urn?
it may not be screwed in correctly -- the spigot. mine seems to get out of wack after just being stored for a while
Jul 16, 2009 | Faberware 10-22 Cup Coffee Urn
Faberware Coffee Urn 55 cup
I was able to buy a spigot for my Farberware Coffee Urn FSU236 from Mxim/Toastmaster in Macon, MO PHONE: 1-800-233-9054
Jul 25, 2008 | Faberware 12-55 Cup Coffee Urn
Jan 09, 2008 | Pasquini Livia 90 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Farberware Coffee Makers & Espresso Machines Experts
Ed Mac
Kolbrun...
Are you a Farberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
