Question about Procom Heating & Cooling
We have a procom small gas heater. We will have it on and all of sudden it will make a booming noise and go out. We will turn off and then restart and it starts and is good for awhile.
    Top Expert:
  • Procom Master
  • 49,228 Answers
The noise could be a build up of unburnt gas ( slow leak in the line before the jet) that reaches a point where it ignites and blows out the jet flame
This is a situation that you need to get a gas fitter in to find the fault or the next big boom could be the house exploding
Posted on Dec 20, 2016
My procom heaters pilot stays on fine but when i turn it to on the flame goes down and heater goes out
I wold check gas pressure to your heater. If it's natural gas it should be about 4 ounces at gas valve. If it's propane/L.P. it shoul be about 7 ounces. If you have a gauge that you can check the pressure with there is usually a port on gas valve that is plugged and usually stamped test. Hope this helps you, Thanks
Nov 17, 2010 | Procom ML300TBA Heater
Where can I get a Charmglow gas heater pressure regulator Procom NRV81F-10? The regulator is leaking propane badly. Thanks.
There will be a number printed on the side of the regulator, contact Procom direct or just put the number into google search and something will come up.
Mar 14, 2010 | Procom QL300TYLA Heater
Procom propane heater will light the pilot but not the burner
the pilot and clean the injector and see if this is clear then try it , you will need a pressure gauge to check the gas pressure ,
Feb 03, 2010 | Heating & Cooling
Vent Free Blue Flame heater: shuts off
Sounds like a gas pressure problem. Have your gas company check the pressure.
Jan 31, 2010 | Procom (177653) Utility Heater
Convert a procom heater from propane to natural
you need to find a place that makes your type of heater and they will have a change over kit all it is different orfices and jetcovers for each gas jet from your heater its self explanitory once you see the parts,sometimes there are different gas comp. that if you use there service they will change you over at no or little cost. hope this helps
Sep 14, 2009 | Procom ML300TBA Heater
Looking for: ProCom Model MNO60HBA (about 3 years old) 6000BTU-Natural Gas-Serial#3620775. I want 3 of the plastic like adjuster knobs on top of the heater. Not the igniter button but the one to allow gas...
Control knobs can be purchased from Procom customer service at 877-886-5989. If you can't find them there, call Kozy World's customer service department at 800-776-9425 and tell them you need a control knob for a KWN109 (same size heater, manufactured by Procom, so same control knob).
Mar 07, 2009 | Procom ML060HPA Heater
Gas smell from Procom 28000 btu infared heater
check the connections with some washing up liquied and water in a bowel and try the connections with this , it should help find your leak use a paint brush to put on
Jan 13, 2009 | Procom (177653) Utility Heater
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Heating & Cooling Logo
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
