Question about Whirlpool Washing Machines
I have an older model Whirlpool Duet Washer (bought in 2009), how do I find the error code? I read the manual and counted the flashes like it said.
    Top Expert:
  • Whirlpool Master
  • 80,339 Answers
Posted on Dec 20, 2016
How do I fix a F11 code on Whirlpool duet washer
Error code F11 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.Aug 25, 2009
give it a try - worth unplugging and plugging back in.
Jan 29, 2018 | Whirlpool Washing Machines
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
What is the F20 code on the whirlpool duet front load washer?
Whirlpool WasherDuet Repair F20 Error Code - YouTube
www.youtube.com/watch?v=kYuRQNbR9Nc
  • By Mike Murphy ·
  • 110,010 views ·
  • Added May 11, 2011
How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer error E3/F8
RTM. Read the manual. If you misplaced the manual, get on by going to Google, put in your make, model and the word manual and you should get the .pdf file of your manual, download it and read it.
Oct 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
Whirlpool duet washer F21 error code. Just bought
"F21" is a Long Drain error. The following link explains how to torubleshoot:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
What this usually means is that you have something clogged in the drain pump and it needs to be cleaned out. In the majority of the cases, this corrects the problem. However, if you JUST purchased this washer, and it is brand new (not used), I would recommend you use your manufacturer warranty (good for the 1st year in most cases) to avoid the risk of voiding it. The conditions of some warranties, prohibit the consumer from opening the appliance and attempting any repairs. Read the find print just to be sure.
If you have any questions, please let me know. I hope this helps you.
Jul 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Older whirlpool duet washer has error F11
F11 is a serial communication error between the central control unit and the motor control unit.
Unplug the machine and open the panels.
Unplug and re-plug all wire connectors from the ccu to the mcu.
Inspect all wires and harnesses for a bad wire.
Could be bad components; ccu or mcu or motor
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Sal De
Gerry Harvey
Gerry Harvey
