Question about Locks & Locksmithing
My Yale digital deadbolt doesn't open using the code we set. It chimes a different tone and the Yale sign lights up red and blue. It will still lock when the 1 is pressed.
Could the cold be an issue? Could a user mess up the lock combo enough that it won't work? Could it need a battery replacement? Help.
redsfans10
  • 28 Answers
SOURCE: phone lock code is on,forgot 4-8 digit answer
try 123456.or you make new format,but remember to save u data or it will lose.if you not sure i think u sent it to shop..
Posted on Jun 13, 2007
  • 4 Answers
SOURCE: proline locking issues
The Proline manual (comes on a CD with the player) says:
6.3.7 Key lock
This function sets a time delay from when key lock function is started or the player is switched on, after which the player will automatically stop responding to the control buttons. Pressing any button will then display the message ‘Locked’. Key lock is useful, for example if you put the player in your pocket and don’t want any buttons to be pressed accidentally. The time delay is to let you start playing the music and so on. You can choose a delay of ten or thirty seconds, one, three or ten minutes, or you can disable key lock completely. •
Press and hold the V+ button for a couple of seconds to temporarily unlock the keys.
Posted on Sep 05, 2008
SOURCE: door chime code for GE model 1601S &1602S
Hi there. I think I have the same GE chime. It has a series of 4 dip switches on the bell (base) and also in the switch unit. Just make them the same. On mine for example, switch # 1,2 & 4 are up (on) and #3 is down (off). Any combination of 16 codes should work as long as both units are the same. Just as an aside, I had a problem with mine working intermittently, then mostly not at all. It was the actual pushbutton switch inside the button unit. Luckily, I replaced the micro-switch and it's working again. Also during cold wet weather, the 12v battery gets depleted faster than normal probably due to moisture inside the switch unit. I taped a piece of plastic from a sandwich bag over the switch unit to help keep water out.
I hope this helps.....
Posted on Dec 16, 2008
moeshere
  • 33 Answers
SOURCE: craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Posted on Apr 05, 2009
SOURCE: Schlage FE365v keyless entry lock.. Lost manual. Forgot 6 digit programming code. Need instructions to restore and set all new codes.
look on the sticker located inside the outer panelo on the lock. you are going to need to disassemble the unit but it is in there.
Posted on Aug 08, 2010
Yale alarm troubleshooting
Dc1 refers to door chime one of the doors or windows are not closed well or not making a complete connection click all windows and doors and try to rearm
Sep 03, 2014 | Home Security
Setting the codes for the door chime
Presuming that you are asking how to set codes for the Desa International door chime, here's a solution:
There are two components of the Desa door chime --- the ringer assembly and the door button. Inside each component is a set of eight pairs of pins and several square-ish plastic jumpers. To set a code, you must push jumpers onto the pair of pins for each of three different numbers. (You may find that you have more than three jumpers. If so, the others are spares which you can tell because they will only be covering one of the two pins in a pair.) Whatever three numbers you choose, the ringer and button must match exactly. 5-6-7 seems to be the default set-up as delivered from the factory. This is only a problem if anyone else in the neighborhood also has a Desa chime with this setting. If you use pin 8, the ring changes from a two-tone chime to a 16-note sequence.
Aug 26, 2014 | Desa International White Wireless Plug In...
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I have a gate house electronic keypad deadbolt, but I lost the book. I need to know what to enter to change my passcode
Try this:
1. Press [SET] button for more than 2 seconds.The red LED will light and the lockset will beep twice.You are now in programming mode.2. Enter 123456 (or current programming code) and then press lock button. The red LED will light continuously for 10 seconds.Enter new programming code (six digits) and then press lock button. The red LED will light continuously for 10 seconds. The new programming code is effective.
Dec 04, 2012 | Locks & Locksmithing
The combination on my Yale Y 150 changed when i locked it how do i open it now?
sorry my friend you are just going to have to break it to get it off once that happens you can change it
Jul 28, 2012 | Electrical Supplies
I have a Defiant Electronic deadbolt from home Depot. model G1X2D01. ive lost the manual and i need to delete some old codes from it.
Snap off the back cover (opposite where you punch the numbers) by pinching the sides and pulling off. Do not press a pen or anything into the small light, you do not need too. Just pinch and yank off cover. You will see a small light and beside it is a small SET button by the batteries, it is labelled.. Press this Set button for 2 seconds. The red LED will light on the front code side and beep twice to indicate you are in programming mode. Enter your current code that you want to change (factory set is 12345) and then press the button that looks like a little lock on the keypad. Enter the digits "10" and press the lock button again. Enter the new code (must be six digits) and then press the lock button again. The red light should go on continously for 10 seconds. The code should be effective.
Note: if you have problems like we did, you can also remove one battery and press the "set" button simulataneously when you reinsert the battery. This resets the factory code of 12345. Then you can start over. For some reason our old code was only 4 digits, but it would not let us reprogram a 4 digit code. It didn't work until we did a 6 digit new code.
Apr 15, 2012 | Locks & Locksmithing
Replaced my transitor battery on my front door. push enter from outside the door enter turns green ......turn deadbolt and it locks. Tried to open door, push the lit numbers of " 4 digit code" enter key is...
Kwikset's warranty covers one year electronics defects and lifetime coverage for the mechanical movement and finish.
Here is a link to it:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
You can contact them from there for further assistance.
Oct 21, 2010 | Kwikset Powerbolt/Electronic Deadbolt-...
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
2001 Chevy Malibu has a 3 tone alert beep that I don't recognize, it's not the regular chime for door open or trunk open what is it. Have had no start issues with car and theft lock is flashing
That model was known for lock cylinder ans ignition switch problems for the no start and theft lock concern.The chime issue could be a problem or not check in your owners manual for chime sounds.I remember when working on these cars they have different chime sounds for different selected options that could be changed and I also had some problems with the BCM body control module causing some weird issues with these models.
Jan 11, 2010 | 2001 Chevrolet Malibu
Locks & Locksmithing Logo
106 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
