Model e3eb-015h element keeps kicking on and off what could be causing this
5 Suggested Answers
  • 1015 Answers
SOURCE: the blower turns off but
It sounds to me like you have a transformer that is going to need replaced before too long.It is normal for a transformer to make a low humminig/buzzing sound that you describe but as they get older sometimes they get quite loud.The good thing is they are not hard to replace nor are they very expensive.
I have seen them just be loose on their mounting screws and you might get by just tracing the sound down and tightening the screws. Thank you and good luck.
Posted on Feb 11, 2011
heinzhvac
  • 229 Answers
SOURCE: how do u wire athermostat
You need to get low voltage wire known as 5 wire. run wires thru wall to stat and furnace Red wire goes to R terminal white to W terminal Green to G terminal Yellow to Y terminal on both the stat and furnace circuit board. Now you need a wire called 2 wire low voltage wire run that from furnace circuit board to outside A/C. At furnace hook red wire to Y terminal and white to C terminal doesnt matter which ones you hook up at outside unit. Do it just like i told you this will work properly.
If this helps please rate me.
Posted on May 20, 2011
  • 51494 Answers
SOURCE: e3eb-015h. What size are the filters?
do you not own a yard stick or tape measure .
Posted on Nov 15, 2015
E3eb-015h. What size are the filters?
Nov 15, 2015 | Intertherm Heating & Cooling
I have a nordyne furnace model # e3eb-017h. Furnace doesn't kick on at all. No relay click or anything but it's getting power. Did the thermostat trick with touching wires together to kick on the furnace...
Check the pilot light sensor. Have seen this issue before. Sometimes after lighting need to hold it in longer. If it doesn't detect the lit pilot wise it will sit in safety shut down mode
Oct 28, 2014 | Heating & Cooling
My intertherm e3eb-015h electric furnace will not do a thing even temp.on thermostatdont show up breakers are on still nothing
Check to see if the fuse is blown. If it apprears to be blown, replace it. It is inexpeisive and simple. If you locate the fuse, you will be abel to determin if it is blowin becuase you will be erruption or a burnt mark in the fuse wires.
Sep 21, 2014 | Heating & Cooling
How do u wire athermostat to the furnance and ac unit on model e3eb-015h nordyne
May 20, 2011 | Heating & Cooling
The blower turns off but the unit keeps making a loud humming/buzzing sound intertherm E3EB-015H
Feb 11, 2011 | Intertherm Heating & Cooling
Red reset button keeps kicking out, i reset button and works fine for a day or two then kicks out again
The reset button kicks out because the thermostat detects overheating.
Anything over 150 degrees, the reset kicks out.
This is caused by 4 things.
1) Bad upper or lower thermostat. Thermostat sticking in 'on' position and elements overheating water.
2) Factory-installed insulation and cover are removed
3) Bad element shorted to ground at center of element, and element continues heating with 120V through the ground wire.
4) Loose wire near upper thermostat, that is shorting and causing heat.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Solution:
Check for missing insulation.
Check for loose and burned wires.
Replace both upper and lower thermostat.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
If problems continue, test water heater elements and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If you need more help, add a comment and I will respond.
Oct 29, 2010 | Reliance & 40 Gal Electric Mobile Home...
Fan Only Won't Work
I jumped the rc and rh wires in the therostat box and now have fan only when selected.
Jul 01, 2008 | Heating & Cooling
Open Questions:
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
