Question about Cell Phones
While selecting a WLAN network i put in wrong password now i cant get past authentication problem
2 Suggested Answers
PABLOCSA
  • 1124 Answers
SOURCE: passwords
You can fix your problem here: http://www.petri.co.il/forgot_administrator_password.htm
Posted on Sep 25, 2008
Reset password on wireless router
That more than likely mean you have put the password in wrong or you are using the wrong authentication type.
For Windows XP below:
Click Start/Control Panel/Network Connections then Right Click on the WirelessNetwork Connection and select Properties. When the Properties window openclick the Wireless Networks tab. Click on the SSID for your wirelessnetwork that you connect to and the Properties window will open. You canchange the Authentication Type to match the type set in your wireless routerand you can also change your password or Network Key to make sure you have itin correctly.
For Windows Vista below:
Click Start/Control Panel/Network and Sharing Center then look to the left ofthe open window and click Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
For Windows 7 below:
Click Start/Control Panel/Network and Internet/Network and Sharing Center thenlook to the left and select Manage Wireless Networks. Find the SSID of thenetwork that you connect to and double click it. When the window opensclick the Security tab to change the Security Type (which is theAuthentication), The Encryption Type and the Network Security Key (which is thepassword).
Jun 08, 2012 | NetGear N300 Wireless Router
Dell vostro a860 won't connect to internet
Why not? Do you have the wireless turned on? Did you put the correct password in?
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
If you put the wrong password in, it will never connect. it will keep trying to connect but never will.
Authentication
That means you probably don't have the password or the Authentication Type set correctly.
Click Start/Control Panel/Network Connections then Right Click on the Wireless Network Connection and select Properties. When the Properties window open click the Wireless Networks tab. Click on the SSID for your wireless network that you connect to and the Properties window will open. You can change the Authentication Type to match the type set in your wireless router and you can also change your password or Network Key to make sure you have it in correctly.
Click Start/Control Panel/Network and Sharing Center then look to the left of the open window and click Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
Click Start/Control Panel/Network and Internet/Network and Sharing Center then look to the left and select Manage Wireless Networks. Find the SSID of the network that you connect to and double click it. When the window opens click the Security tab to change the Security Type (which is the Authentication), The Encryption Type and the Network Security Key (which is the password).
May 28, 2012 | Dell Vostro A860 Notebook
Thinkpad having limited to no connectivity
More than likely your password is wrong or the Authentication Type such as WEP, WPA, WPA-2 is wrong.
May 11, 2012 | Lenovo ThinkPad T420 Notebook
Dell inspiron 8000 password authentication system
Are you talking about the authentication process on trying to connect using wireless?
That means you probably don't have the password or theAuthentication Type set correctly.
May 10, 2012 | Dell Computers & Internet
No wifi toshiba satellite a665d s5178 un able to install a wireless drive and fnf8 doesnt work
Is the wireless switch on that is located on the side or front of the laptop?
Did you ever see any wireless networks to connect to? If so, did yours try to connect? maybe you have the password/network key in wrong. It will never connect if the password is wrong.
May 09, 2012 | Toshiba Satellite A665D-S5178 15.6-Inch...
Cant conect to 02 internet on nokiac3
go to menu->settings->connectivity->wlan->internet connection
Please check your phone sw version from this link and update if necessary.
Please do not forget to back up your phone before you update.
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
The latest sw is 4.60 depending on the sales areas and variant.
Please also become familiar with the FAQs :
http://europe.nokia.com/support/search?comp=Nokia+C3-00&qt=wlan
How do I manage WLAN internet access points on my Nokia C3-00 device?
How can i use always WLAN connection on my Nokia C3-00 phone for Internet instead of GPRS?
I hope this helps.
First of all you delete all current settings, these are for 02 and will not work on giffgaff. To delete settings:
  1. Press the navi key and go to Menu
  2. Go to settings
  3. Go to configuration
  4. Press the navi key on Default config. settings
  5. On both 02 Pay&Go and 02 paymonthly press the backspace key (inbetween the p and enter key)
  6. Select Yes to delete on both
Now that you have done that you need to set up the giffgaff settings, I recommend using this method to do it:
  1. Go back to configuration
  2. Select personal settings
  3. Select Options then Add new and then Web
  4. Put the Account name to anything you want (I put Giffgaff web)
  5. Put the Homepage to anything you want (I put http://www.google.co.uk/)
  6. Put the Username to giffgaff and the password to password
  7. Put Use preferred access pt. to No
  8. Select Access point settings
  9. Put Proxy to Enabled
  10. In the Proxy address type 193.113.200.195 and select OK
  11. In Proxy port type 8080
  12. Go into Bearer settings
  13. In Packet data access pt. type giffgaff.com
  14. Put the Network type to IPv6 (IPv6 appears to be faster)
  15. Leave the Authentication type at Normal
  16. In User name type giffgaff and in password type password
  17. Go back until you see your Personal accounts and press Options on your settings and select Activate
  18. Go back again and in Default config. settings select Personal config.
  19. Finally press Default in all apps.
Now that you've done this set up the packet data settings:
  1. Go back and select Connectivity and then Packet data
  2. Put Packet data connection to When needed and select Packet data settings
  3. In Active access point select Access point 5 (Access point 1 is known to have some problems, select Access point 5 to be on the safe side)
  4. Go into Edit active access point
  5. In Access point alias type whatever you want (I typed in Giffgaff)
  6. In Packet data access pt. type giffgaff.com
Okay so finally for wifi settings:
  1. Go back and go into WLAN
  2. Select Internet connection to Ask first (so that you can choose to use wifi)
  3. Now select Available WLANs and wait for the search
  4. Simply find you WLAN, select it and enter the security password for it
  5. When it asks Save network for future use select Yes
Now you have giffgaff internet and wifi set up on your Nokia C3-00! For any issues you can message me, I will be willing to help!
Update: You may be experiencing problems with using wifi with the browser or any other application, do this to fix it: "I had the exact same problem. What I did was that I removed all network Internet settings, GPRS, WAP, etc. because I do not want to use them which is when I lost the ability to select which AP to use.
So what I did was I created a personal setting:
Settings > Configuration > Personal settings > Add > Web
Then go to the main menu > Internet > Web settings > Configuration Settings > Select the personal settings that you created
Now try to access the internet and it will ask you to choose, choose Wi-fi
Then go back to the personal settings and delete the setting that you created. From now on, you will be asked which connection to use everytime you access the internet
If you want to restore your GPRS settings, you can just request it from your network provider and they will send it to your phone."
Source http://discussions.nokia.co.uk/t5/Cseries/ANOTHER-NOKIA-C3-WLAN-PROBLEM/td-p/754515
Dec 03, 2011 | Nokia C3 Cell Phone
How do you connecct the wireless printer to my wirelss router
  • On the printer,push the MENU button,push the up or down button to go to select network then press the OK button.
  • under network menu go to WLAN then press the OK button to confirm the selection.
  • under WLAN menu go to setup wizard then press the OK button
  • when Network I/F switched to wireless is displayed ,press OK to accept.the printer will search for available networks.
  • select your SSID or network name on the list it will display then press OK.If it only showed your SSID then just press OK.
  • Use the a,b and OK buttons to choose the one of the options below:
  • no authentication or encryption or password , select open system ,press OK then choose none for encryption type.press OK.
  • No Authentication with WEP Encryption:Choose Open System, then select and press WEP for the Encryption Type and press OK.
  • Authentication with WEP Encryption:Choose Shared Key and press OK.
  • Authentication with WPA/WPA2-PSK (TKIP or AES) Encryption:Choose WPA/WPA2-PSK and press OK
  • after selecting the correct option,press OK.Always remember,WEP or WPA keys are case-sensitive.You can use the ? and ? keys to move the cursor left and right. For example, to enter the letter a, press the 2 key on the dial pad once. To enter the number 3, press the 3 key on the dial pad seven times.The letters appear in this order: lower case,upper case and then number.
  • press OK after entering the password.
  • the printer will attempt to connect to the router.If it successful,it will display the word connected on the printer.
note: you need to know the encryption type and password type (wep or wpa) for the wireless setup to be successful.you can get the info you need from your router account page or GUI.
Jul 17, 2011 | Brother MFC 490cw Color Inkjet...
I cannot connect my nokia c7 to the internet through wifi
Hi, pls verify below steps,
1.Whether WLAN switched on and has a good WLAN coveage. 2.Security settings on WLAN options
- Check the security modes (Open/WEP/WEP2 - this depends on your WLAN connection) - Check Security settings (Public shared Key settings)
3.You have to be a authorized user in WLAN network if it requires authentication login. 4.Open the browser on you mobile and select General->Connection->Always Ask, then it will prompt for the connection type, Select WLAN.
Thanks, Ramaly
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
Sir am trying to coneect my samsung GT-S5233W to WLAN & its all ways gieing me disconnected or Authentication failed please need help if am doin some thing wrong appreciate your kind reply
Before trying to connect to the WLAN
get the SSiD ( Network Name )
Password ( WEP /WPA )
And then try connecting to the network
If it is your home network then , Change the Security to 64 - Bit WEP
And change the Wireless Channel to ' 6 '
Change the network Name into a much simpler one ( without spaces )
Scan and connect to this network
Regards
TOM
Dec 24, 2010 | Samsung Star GT-S5233 Cell Phone
I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Jan 08, 2010 | Samsung Omnia Pro B7320 Smartphone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
