Question about Vizio Audio Players & Recorders
THE PICTURE ON MY VIZIO NOW HAS ABOUT AN 8-10 'GRAY FILM GOING ACROSS THE SCREEN,WHICH AS LOWER THE PICTURE QUALITY.IT IS A 48 VIZIO,
HOW DO I GET A TECH TO MY HOME TO FIX IT??
techman
  • 3130 Answers
SOURCE: Picture Quality
without seeing a picture I can guess that you may have a shorted green crt or the drive going to it has changed and you may need to turn down the g2 control for the green. If the tube is shorted or bad see what type of warrantee you have on the crts as some sets have two to 5 years. Good Luck
Posted on Apr 22, 2006
SOURCE: Red Dots on My Plasma.
Did you get this problem resoslved? I had the same issue a few months ago. I tech came by and took my TV to the shop, a few days later he said it was fixed as they needed to make some adjustments.....The TV has been fine up until a week or so ago and now the red dots have appeared again. Was wondering what happened to yours.
Posted on Dec 28, 2006
SOURCE: canon zr200 Gray lines
Change your resolution and it should go away.
Posted on Jan 06, 2008
SOURCE: Vizio P42 Plasma HDTV10A
THE CABLE INPUT IS SERVED ON 22" VIZIO HOW AND WERE CAN I GO TO FIX THIS PROBLEM IN ATLANTA
Posted on Nov 13, 2008
SOURCE: vizio p50hdtv10a no picture, gray screen
This could be several things. It could be the main board 3850-0042-0150 or the plasma controller board 6871QCH083A.
Depending on what you actually see on the screen it may as well be bad Y sustain board (although less likely).
Unless someone has seen that particular issue in that particular model (or other that share the same deffective component) it will be anyone's guess which is the exact module. They all can be causing what you describe.
Since TV shuts itself in one minute I'm leaning towards the main board.
I'm afraid you'd have to either experiment or bring it to a service center that will either have such a TV and can try or will experiment on your behalf. Just make sure you do not pay for boards they experiment with. I know some of the other TV service shops in our area (and without a doubt elsewhere too) do that.
A TV service center (just as anyone with regular contacts with eBay) can resell incorrectly ordered part and end up losing $10-$20 on it which , if split between customer and technician, I think is completely fair. Just make sure you don't end up paying for a board that was ordered and turned up not the one in fault.
bobby
www.coppelltvrepair.com
Posted on Oct 31, 2010
Turn the TV on black and gray vertical lines going across the screen (like pen stripes) and can only be seen in the black or dark areas after 10-30 minutes they disappear and the screen is fine.
In most of the case, the problem is a defective data buffer IC located on the flex cable between the LCD panel & the panel buffer board, this problem can't be repaired, you have to replace the panel
Aug 29, 2017 | Vizio Televison & Video
My Vizio E470i-AO has a light gray horizontal streak about 6-inches wide that runs across the entire screen with a tapered vertical tail about. We can watch TV, but the picture is not as sharp.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 24, 2015 | Vizio Televison & Video
Best picture setting for vizio E480I
Go to the main menu and find settings. You can set the default screen parameters there.
Keep in mind that there are still channels which are not yet providing HiDef video to carriers,
Dec 19, 2014 | Vizio 48-inch LED Smart TV E480i-B2 HDTV
Vizio VW46L10 TV has a 6 inch dark band across the top of the picture.
Change input device to some other like a DVD player.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry. If problem persists, call in a qualified service technician.
Aug 02, 2012 | Televison & Video
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
Vizio 1080p model VU42LFHDTV10A clicking and blackish/ gray screen no picture
have you tried changing the "input" button is on lower left corner. If you have a DVD/VCR hooked up, change input to that, if still same thing then the high voltage power supply might be bad.
Mar 31, 2011 | Vizio 42 in. LCD TV
JVC 48" AV-48P776
no se ve bien los colores jvc 48 776
Nov 02, 2008 | JVC AV-48P775 48" HDTV
May 19, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
GE model 31GT660
Is the brightness in the middle of adjust range? Is the picture
or contrast adjust at 3/4 ? Next,adjust the screen voltage on
lower rear of cabinet = one control is focus and one is screen..
how is the picture now ?..........................T.
Feb 11, 2008 | GE 31GT660 TV
Toshiba 32AF42 Poor picture quality
TRY ADJUSTING THE SCREEN CONTROL ADJUSTMENT AT THE BOTTOM OF THE FLYBACK TRANSFORMER.THIS SHOULD REMOVE THE RETRACE LINES AND ANJUST THE HASY LOOK TO THE PICTURE IF NOT YOU HAVE A BAD CAP IN THE SCREEN CIRCUIT .LOOK FOR A 10MFD/250V CAP IF FEEDS THE NECK BOARD ATTACHED TO THE PICTURE TUBE 200V DC.
Jun 22, 2007 | Toshiba 32AF42 32" TV
37 people viewed this question
Top Vizio Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
