Question about Samsung Televison & Video
Hi, does anyone know where I could get the following Samsung 42" models?: HCM 4216H, HCM 4216W, HCM 4215W, HCM 422W and SP42 W5HF. Urgently need to get hold of these. Any ideas greatly appreciated.
    Top Expert:
  • Samsung Master
  • 80,530 Answers
We do not sell or have listing for these.
Posted on Dec 19, 2016
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
Jan 28, 2015 | Blanco Ovens
Have blurry picture,more on the top right of screen,is there an adjustment for the focus onthis unit.Model#hcm-422w
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 27, 2010 | Samsung HCM422W 42" Rear Projection...
I HAVE AN HCM 4215W SAMSUNG 42 INCH TV THAT WILL WORK FOR ABOUT 20 MINUTES THEN SHUT OFF...I USE THE REMOTE TO TURN IT ON BUT ONLY THE RED LIGHT COMES ON. IF I UNPLUG IT AFTER ABOUT ONE MINUTE THE LIGHT...
Having in mind that a generic lamp will give you 4500 to 6500 lamp hours and the Phillips will give you 6000 to 8000 lamp hours and that you TV is 4 years old more likely you are looking to replace you lamp;The lamp itself typically uses AC current and about 15,000 volts to ignite the lamp's mercury vapor gas. The gases inside the lamp react when electricity charges up the mercury gas creating very bright light. The voltage drops to keep the flow of electricity to the lamp.
If you can hear your TV fan working is NOT you power supply,but if you hear a constant clicking you BALLAST needs to be replace,
A ballast is an electrical component used with a fluorescent bulb (or mercury vapor lamp or arc lamp) to conduct electricity at each end of the tube. It supplies the initial electricity to the bulb that creates light, and then it regulates the amount of electricity flowing through the bulb so that it emits the right amount of light.
You can find your parts at:http://www.discount-merchant.com/SearchResults.asp?Search=HD50LPW175?Click=52978
I hope this will help,please keep us posted.
Oct 15, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM 4215W when on, no picture timer blinks & chirp sounds
Sounds like a shorted component in the power supply or the high voltage circuit.
Time to call a professional.
Apr 10, 2009 | Samsung HCM4215W 42" Rear Projection...
My Samsung projection TV, model HCM 4216W has developed a yellow tinge on the lower left of the screen. Though it is visable I can live with it.Can I expect it to get worse? Is there an easy fix? Thank you...
convergence misaligned possibly realignment could solve this but it is usually the first sign of weakening converge ic's keep these units as cold as possible as heat kills them
Oct 06, 2008 | Samsung Televison & Video
Samsung Tantus HCM 22 convergence problem
Check this website to buy the entire convergence amplifier board. Replacing the entire boars is a DIY since there isn't any soldering involve only open back cover of the TV and unplug a few wires to remove the old board and install the new one. Keep in mind that this board could be used or reburbished.
Samsung no longer has the assembly.
If you need more info let me know.
Aug 28, 2008 | Samsung HCM422W 42" Rear Projection...
Samsung SCX 4216F which rj11 cable do i need
It needs only two pins - more is OK but not required
Feb 04, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Sp42
you can get the servic manual emailed to you from this link.
http://servicemanuals.vstore.ca/
Nov 04, 2007 | Samsung PCN5425R 54" Rear Projection...
Open Questions:
Televison & Video Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
