Question about Sharp Televison & Video
Need DUNNTK558FM02S Mainboard to tcon "LB" connector cable pin out or cable part number. Thanks. PS- Is for a Sharp LC-46SB54U tv
  • 2,326 Answers
I might have that part. Email me at for more info.
I can send to you because I have no use for it..
Posted on Feb 08, 2017
  • 1077 Answers
SOURCE: error code e203
My sharp manual says E203 means "No broadcast now".
Under possible solution, it says " Check the broadcast time in the program guide".
My manual says nothing else after that.
I hope that helps. Please rate me. :)
Posted on Mar 01, 2009
  • 57 Answers
SOURCE: Need owners manual for Sharp 46'lCD TV Mod.#LC-46SB54U
Owners manuel can be found at right hand side--enter man and model #, to avoid having to sign up, right click and open in a new window when the pdf file pulls up. Its their I just checked.
Posted on Feb 24, 2010
SOURCE: No sound in Sharp 46" LC-46SB54U TV
little sound for sharp lc-46sb54u
Posted on Oct 17, 2010
  • 8197 Answers
SOURCE: manual needed for sharp LC-46SB54U TV
You can get the manual on the link below.
Good Luck
Posted on Dec 04, 2010
  • 1591 Answers
SOURCE: the tv will not come
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably come on and maybe stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Apr 11, 2011
T-con board or maim Board issue? Disconnected T-con from the main board and got back light! sharp lc-55le55ou
Hook the Tcon cable back up and do this. With a program running on the TV, shine a flashlight in the screen. If you can't see movement from the program, then the Tcon board is bad. you can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 02, 2016 | Sharp Aquos Televison & Video
Power and OPC blinks, TV will not change Input modes
Try removing set and or a box if used from power for several minutes.
Dec 23, 2012 | Sharp LC-46SB54U LCD TV 46 inch Class,...
I have a sharp 32av22u which has vertical lines and at moments i get a picture and sound and then lines appear and screen fades to multi color but still have sound
This is a problem with the LCD's inverter cable, the cable that connects the LCD to the mainboard. Have it checked, reseated or replaced by a certified technician to prevent damage of other parts.
Sep 05, 2011 | Sharp LC-32AV22U 32 in. LCD TV
I have a 46 inch Sharp model #LC-46SB54U. The
no_picture.jpg Part Number NOTE Description Product Note Substitute Part n/a Total Availability 0 Estimated Ship Date no longer available
Apr 27, 2010 | Sharp Televison & Video
Feb 24, 2010 | Sharp LC46SB54U 46 in. LCD TV
Televison & Video Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
