Hi can I connect my talk talk box up to sky router I'm using it as a free vie box but would be good if could use the apps and use net fliks
SOURCE: how to connect projector to sky plus box using RGB
i have same problem as above can you advise please
Posted on Jan 02, 2009
  • 40 Answers
SOURCE: Not able to connect to internet, using wireless router (SKy),
One of the things that I have seen that might fix this problem is running a program called winsock fix. What this does it reset/rebuild your network config on your laptop. You will need to download this program from the other computer and then take it to the laptop via thumbdrive/cd. Here is the link. Hope it helps.
http://www.snapfiles.com/get/winsockxpfix.html
Posted on Apr 10, 2009
SOURCE: Cannot connect to sky router
sometime this would because your router is thinking that your phone is a hacking device and so it will not allow full connection so if you put a password on you router it would probily fix your problem
Posted on May 28, 2009
yboyandrei
  • 828 Answers
SOURCE: My brand new Net-Talk USB phone won't connect
try to remove again your new Net-Talk USB PHONE, this phone is automatically detect on system, if this device did not connect properly on USB, it will not work, or maybe you USB front panel, try to put it at the back or in the USB Mainboard connector. Good luck!
Posted on Jul 22, 2009
anandg27
  • 1272 Answers
SOURCE: I have Sky Broadband withe netgear router. Bought
HI,
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as sky (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
scan for the wireless network on the computer with the adapter and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Aug 03, 2009
Sky anytime+
Call Sky - the guys on the help line have a code which takes you to an advanced menu where your broadband can be setup properly for your router. It sounds as though the box and router are conflicting - happened to me :'
Apr 30, 2012 | NetGear DGN2000-100NAS Router
Cannot login into my netgear dg834gb v2 for remote management
Here is a site for your new firmware version:
http://kb.netgear.com/app/answers/detail/a_id/262/~/dg834(v1-%26-v2),-dg834g-(v1-%26-v2)-firmware-version-2.10.22
Here is a site for your product:
http://kb.netgear.com/app/products/model/a_id/2324
Maybe you have to reset it to factory settings.
There is a button next to the power inlet prees it with a pen.
Here is how you acces the router again:
  • IP address: 192.168.0.1 type this in your browser
  • Username: admin
  • Password: password (Sky-branded units have a default password of sky)
  • Function set to Router + Modem
To access the Setup Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
A video walk-through of installing and configuring your router using the Smart Wizard is available at http://kb.netgear.com/app/answers/detail/a_id/12873.
Hope this was helpfull.
Mar 17, 2011 | NetGear DG834G Router
Hi can my flatron L1718S monitor be connected to a sky box for use as a TV? thanks
You will need another box to convert the output signal from Sky box to VGA output to feed the monitor. Juts Google ' Video to VGA adapter'. For example:
http://www.thenerds.net/STARTECHCOM.StarTechcom_Composite_and_S_Video_to_VGA_Video_Converter.COMP2VGA.html?affid=8&productads=1
You may also need a good set of powered speakers for good sound.
Please leave rating if it helps.
Feb 04, 2011 | LG Flatron L1718S LCD Monitor
Hi i am using Belkin N1 vision version 102uk when ive plugged this in to the sky adsl router, it is showing no router detected?? can you help?? regards chris
1. check connection by 1st pinging the network card That is go to the dos window and type " ping 127.0.0.1 you should get 4 replies.
if not then you need to check the driver set for you network card.
2. check the ether net cord with a know good one
3. reset the router by unplugging it and reboot the pc
4.Call your ISP to check for outages
Aug 03, 2010 | Belkin N1 Vision Wireless Router
I need a secure connection
Contact NetGear TechSupport, they will walk you through over the phone and connect to your computer over the internet (if you have wired internet to laptop already to assist with setup of Wireless Security.
ask for level 2 support, otherwise you will spend first 30 minutes talking to someone reading from a manual asking you non-essential questions.
Support is free if your router is still under its warranty.
http://kb.netgear.com/app/answers/detail/a_id/1204
888-NETGEAR, 24 hours a day, 7 days a week.
Good Luck
Feb 16, 2010 | Computers & Internet
Net gear box won't connect wirelessly with my lap
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 20, 2010 | NetGear WGR614 Wireless Router
I have recently joined sky and there netgear wireless box they provided is rubbish so want to use my netgear DG834PN so have logged onto my router and inserted the username and password of my sky router...
Please note that it is not possible to configure a different router, not provided, by SKY on their network. Sky use MAC authentication on their network and hence it is virtually impossible, unless you spoof the MAC address, to configure a different router on their network.
Regards
Anand
Jan 08, 2010 | NetGear RangeMax WPN824 Router
Have moved from sky to plus net and need to
Hi There,
I'm assuming that your router is connected by a network cable;
Go to your network connections, right-click on the connection for your router, select 'status', click the 'support' tab. Make a note of the 'Default Gateway' IP address.
Start your internet browser, in the address bar type the IP address. You should then arrive at your router's control panel.
Hope this helps.
Regards,
MC.
Sep 03, 2009 | Computers & Internet
Sky Broadband Connects for a few seconds and then goes,rarely to return
Use "free" Sky broadband setup disk to automate and save username, password, network connection, LAN/wireless properties, MAC, IP, subnet, gateway, etc on her computer, exactly as your own working system. Change her computer's IP address last digit next available number up or down: yours 192.168.1.1, hers 192.168.1.2 etc.
May 21, 2008 | Computers & Internet
Belkin wireless G desktop network card
What has happened is that the proxy server on your last internet connection is in need of being redetected. you will need to delete any old cookies and internet files, also check in the internet explorer tools>internet options>connection, that the the the last provider you used is trying to connect instead of sky, so either select never dial a connection or sky as your default connection. Also check that in the properties of the belkin adapter that obtain an ip address automatically is checked in the TCP/IP properties. You may also need to refresh your browser a few times before you get on the net. A good temp file and reg cleaner, is Ccleaner, it's free and available at the link below http://filehippo.com/download_ccleaner/
Sep 10, 2007 | Belkin F8T003 Bluetooth (F8T003V) Wireless...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
