Hum coming from speakers
What would cause the speakers to hum?
  • 37 Answers
Faulty wires/ connections are the usual cause of hums on speakers. Try checking if the wires are properly connected. If it still hums, try replacing the wires with a known good wire.
Posted on Nov 20, 2007
Woofer is humming
Usually a faulty cable or blown speaker will cause a humming. If it is a constant humming I would surmise a faulty cable. On the other hand, if the humming comes and goes I would guess a faulty speaker.
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
Low independence light comes on and a humming sound what is causing this?
Humming from subs? If from inside amp, your experiencing a problem with a driver board. It makes transistors latch on and loads down the transformer, causing light to come on. And vibrations "hum" from transformer.
Oct 16, 2012 | Jl Audio 500/1V2 Car Amp
Speakers started making a humming noise
HI:
Usually with audio humming, the cause is due to a bad capacitor on the amplifer portion of the unit. Bad filter capactor in the AC power suppy will cause whats known as AC ripple to enter the system causing motorboating sound or humming. Have the unit check by a technician for poor regulated DC voltage.
May 21, 2011 | Altec Lansing VS2421 Main / Stereo Speaker
I have a 2.1 altec lansing speaker system i got 3 years ago. a couple of moths ago they started humming. the humming is now so loud i have to turn the power off when i go to sleep (i can even hear the hum...
If there is a router or you leave your phone near the speakers that is what is most likely causing the problem. Check to see if anything that gives off a wireless signal (eg. microwaves, cell phones, cordless phones) are nearby, and try to see if moving one of those things fixes your problem.
Feb 28, 2011 | Altec Lansing VS2421 2.1 Speakers
I have an Onkyo TX SR 700 receiver, Bose Acoustic Mass 10 speakers, Panasonic Viera 52" flat screen with my computer connected to the receiver. The computer uses a high end sound card. The flat screen...
Hi, what causes hums from speaker is when there is no ground shield from either the power supply or from the cable you plugged into the socket from the power supply.
So you will need to check that out and replace untrusted cables for connection..
If after doing this troubleshooting exercise, you will now need to test the speaker with another set to be sure the humming sound is not coming from there.
I guess that will Do.
Have a nice day...
Feb 18, 2011 | Bose Acoustimass 10 Series IV Home...
I get a humming sound when the ipod is attached,
the hum comes from three possible sources, the power unit can cause it before failure, the amplifier which can effect one or more speakers or the interface board between the other two, the interface board and the power board are known problems to b and w, so if you have not already contacted service at b and w, then do so.
May 15, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
Left speaker wont work
humming is caused by defective amplifier.either left or right.unless you connector is faulty.try changing the connection cords, first. if not, then call a tech for mano y mano analysis.
May 16, 2009 | Boston Acoustics BA745 Computer Speakers
Strong humming sound coming from the over head speakers
are you running a stand alone dvd player or is it built in?check all plugs for sources coming ineg.dvd,vcr,xbox etc,if one is not in all the way,this will cause a hum.
Oct 20, 2008 | Sony DAV-C770 System
Annoying humming sound coming from subwoofer...
The humming sound usually comes from the DC supply that is not filtered. The a/c converted or changed to DC needs to be "cleaned", before going into the ckt. Usually the capacitor and resistor network go bad, maybe causing the fuse to open. Even if you replace it, u may still have the "humming" because the circuit is still bad.
If you know how to look at the capacitor, resistor,or coils AFTER the diodes & replace the damaged part, u should be good!
Mar 02, 2008 | Boston Acoustics MicroMedia Computer...
359 people viewed this question
 Grubhead
Grubhead
