Question about Hayward 1 Hp Super Pump Inground Swimming Pool Pump 115/230 Volts Sp2607x10
When I turn on my pool pump (Hayward Super Pump), I see sparks and the circuit breaker gets tripped. What should I do?
    Sergeant:
  • 199 Answers
Replace the pump or have it rewound at a motor shop it will take about a week. it is bad and you cant fix it your self normally.
Posted on Jul 21, 2009
My pool motor tripped my breaker. When I reset the breaker and it tripped again sparks came out of the motor. Can someone tell me what the problem is more likely to be? I don't know the make of the motor...
The title description is a Hayward Super II 1.5 HP but the part number you gave is for a StaRite MaxiGlas pump. Either way the motor needs to be replaced.
The best way to find out what you need is to look at the part number on your impeller. With that information whoever you buy the motor from will be able to get you the correct pump and seals..
Oct 30, 2013 | Hayward SP3015EEAZ Super II Pump 15Horse...
My hayward pool pump not working,forget to close the air vent before pump started and is water allover the pump,what to do?
Water sprayed on the pump occasionally shouldn't hurt it but it might cause a ground fault circuit interupter (GFCI) to trip. If you turn on the pump and literally nothing happens then most likely the the GFCI has tripped. If it hums then this is a different issue. If you have a volt meter you can open the timer box and check whether power is available to the timer. If no power is available in the timer then it confirms that the pump is probably ok. Checking your circuit breaker panel for a tripped breaker or finding a tripped GFCI then either one can be reset and your pump will probably run without a problem.
I hope this helps.
Sep 16, 2011 | Hayward Tristar Pool Pump 1 Hp for In...
Pump is tripping circuit breaker
If your pump is tripping the circuit breaker there is a very good change that the motor is bad. you can change the motor or purchase a complete new pump. I would pull the pump and take it to a local motor repair shop and have them check it for you.
Aug 29, 2011 | Hayward 3/4hp Super Pump Inground Pool...
Pump trips circuit breaker/where can i get a wiring diagram for this pump?
The owners manual does not have information on the pumps. You would need to get the model information off of the motor, and request that information from the manufacturer.
Otherwise, all motors have the wiring diagram right on the side of them.
Jun 09, 2011 | Hayward 3/4hp Super Pump Inground Pool...
My hayward 1hp super pump hums when i turn it on but doesn't turn or pump it eventually trips the circuit breaker inside
Inside pump is a difram , it most likely is stuck, some times if you shut off pump, turn back on a few times it might release itself, but most likely needs to be replaced. Let me know, mike from fixya.com
Jun 08, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
Turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Jul 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hello, We have had our Hayward Super Pump 1hp for 6 years with no problems. Just yesterday it started tripping the circuit breaker. It would run between 30seconds to a minute and trip the breaker. Could...
6 years is a good time - you must have house for your pump :)
If you are close to a pool shop - take it in and get it tested - somtimes it will just need a service.
Jul 13, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
My new Hayward Super Pump is over Amping
Sounds like the wire gauge (thickness) is to small
Jun 04, 2009 | Hayward Pool Products Hayward Super Pump
Hayward Super Pump not turning on
it sounds like your pump is stack it could
bee that something is stack in the pump,
try somehow to turn the motor to see what is binding
get access thrue the pump.
G
May 18, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Hayward 1 Hp Super Pump Inground Swimming Pool Pump 115/230 Volts Sp2607x10 Logo
635 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
