Question about Kitchen Appliances - Others
Someone please help me !!! After changing the batteries, I cannot find a way to get any sound out of it whatsoever Not bips nor voive reproduction. Thank you !! George
  • Kitchen Appl... Master
  • 18,342 Answers
On an Electric Grills & Sandwich Makers, the category you posted to?
Posted on Dec 19, 2016
USE A NIKON F-801S GET THE MESSAGE ERROR fEE 8 and a bip bip bip sound the film is new/ battery full / use a lense Tamron af
Turn the aperture ring on the lens to its smallest opening (largest f/number). If the ring has a lock, lock it in place. You can control the aperture from the camera, the same was as on a lens without an aperture ring.,
Mar 21, 2011 | Cameras
When I try to switch it on you can hear the processor go on but nothing happens, the screen stays black and then a very loud bip.....bip...bip occurs; and then..nothing else
  1. Check your power cord & adapter.
  2. If its working then check the battery, reseat the battery & check.
  3. If available then check with another battery
  4. If no, then remove the battery & switch on the PC in AC mode.
  5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
  6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
Aug 20, 2010 | HP Compaq Presario V2000 Notebook
Computer didn't start
The bip-bip sound means that a necessary input/output device is missing or not working. Go to enter your service tag number download the manual (LINK included) if you have questions of how to search Dell Fourms. Please rate me mysleuth
Apr 29, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
It sounds like rotary dialing
I have a similar Panasonic phone (KX_TGA101S).  Someone must have inadvertently changed the dial mode on you.  Here is how you change it on mine, which should be similar to yours.  Hit the Menu button.  Scroll down to "Set tel line" and hit the Menu Button (OK). If it isn't displayed, scroll to "Set Dial Mode" and hit the Menu Button. Select Tone instead of Pulse and hit the Menu Button.  That should do it.
Jan 25, 2009 | Panasonic KX-TG1033S Cordless Phone
RAM Problem
either the ram is faulty or not compatible try using in a different board
the motherboard will beep with no memory in
Jan 17, 2009 | Intel Motherboard
Cmos cheksum bad
From your problem description, it sounds like a corrupt BIOS and or a failing motherboard.
Due to the system age, I'd say cut your losses, salvage what drives are usable, and get a new (or newer) system
Dec 07, 2008 | Computers & Internet
Asrock K7S41GX "NEW" does not work :bip-bip-bip
3 beeps is a memory error. remove the memory and put it in the first slot.
also the memory replacement calls for ddr pc2700.
Sep 05, 2008 | Asrock K7S41GX Motherboard
Phones won't work
A) Ok first try to disconnect everything and connect all the batteries and cable back. Charge your batteries to full. Then if it still Out of range, do this with all your handsets.
- Disconnect the battery
- Hold the * and # key on the Handset and put the battery back without releasing the buttons. (now your in test mode)
- press the 2 softkey below the screen ( it's a factory reset, erase everything)
- You will see RAM/EEprom erase on the screen
-After the bip press end
B) OK! Now disconnect the power adapter from your base unit .
-Hold the memory button on your base and plug the power adapter at the same time. Then the base will bip to let you know that you done it correctly.
-after the bip press No.1 ( that's mean the handset 1 is de-registrer.
- Now De-register all the other handset by doing the part B again. But only changer the No.1 for 2 then 3 then 4.
C) Disconnect and reconnect everything and use your manual to register your handsets with the base and your done! Everything should be ok !
Nov 21, 2007 | Uniden DCT648-3 Cordless Phone
Kitchen Appliances - Others Logo
65 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
