We have an mac 2254 and the summer fan is all that is working no heat is coming out what could be wrong and how can we fix it
We have an older furnace a Mac 2254 and have no heat how do we fix it
  • yadayada
    yadayada Dec 19, 2016
    Hi Anonymous How old is this unit? Is this a USA made product? Are parts still made for it, have you checked?
SOURCE: HP deskjet 1280 printer drivers for latest apple mac laptops
i have no drivers.hp1280
Posted on Nov 21, 2008
  • 39 Answers
SOURCE: CD won't eject. I've restarted and tried all the fixes recommended by MAC forums and so far no luck. Any other ideas?
If it is just the computer that isn't ejecting the disk (and not a physically "stuck" DVD) there is a way to force eject.
Go to Apple menu > Restart and hold down your mouse button until the disk ejects.
Or you can try the firmware method...
If all other methods fail, you can try to eject the disk using the firmware (this may not work on all computers). To use this method, start up and briefly use the computer with only the firmware loaded, not the standard Mac OS X interface.
To eject a disc using firmware:
Restart the computer.
When you hear the startup sound, press and hold the Command-Option-O-F keys. (The Command key has an Apple on it.)
Release the keys when you see a white welcome screen.
At the prompt, type:
eject cd
Press Return, then wait a few seconds. The disc drive should eject the disc, and "ok" appears on the screen when the action is complete.
Type:
mac-boot
Press Return.
Your computer starts up normally and you see the familiar Mac OS X desktop.
Posted on Apr 16, 2009
the_fire
  • 432 Answers
SOURCE: Compatibility with more recent Apple Mac computers
http://imaging.nikon.com/products/imaging/lineup/software/index.htm
You could use virtual box ( unless you want to purchase vmware fusion or parallels ) to run windows or you could use boot camp on one of or both of the macs to run the software
Posted on May 17, 2009
  • 582 Answers
SOURCE: I have a Trane Xe-60 furnace about 19 years old.
THIS IS A COMMON PROBLEM WITH THE DOOR SWITCHES, MY FIRST ANSWER WOULD BE REPLACE THE SWITCH SECOND WOULD BE OPEN THE DOOR AND PUSH THE BUTTON IN AND SEE IF THE FURNACE WILL WORK. THIS SWITCH IS JUST A DOOR SAFTEY IF THIS WORKS. I HAVE TAPED A PIECE ON THE INSIDE OF THE DOOR WHERE THE SWITCH WILL HIT THE DOOR ABOUT A 1/4 INCH THICK AND SEE IF THIS WILL GET YOU RUNNING UNTILL YOU CAN GET A SWITCH
Posted on Oct 12, 2009
billyvangogh
  • 108 Answers
SOURCE: I installed my honeywell rth221b1000 this summer
If when you turn the heat on you hear the furnace fan start up (exhaust fan) then the problem is NOT the Thermostat....need some more info on the furnace...the Wiring in the thermostat should include a Jumper wire between RH & RC if you have 4 wires and no jumper required if you have 5 wires
Posted on Nov 01, 2009
We have royal red furnace to heat our home.The fan dose not stop.
Details.......does the furnace function normally otherwise? Might just be a stuck fan switch. Make sure the thermostat hasn't been set on Fan ON setting or summer air circ. on older furnaces.
Find the fan switch and tap it and see if fan quits. If it does,fan switch is bad.probably. Always make sure your air circ. filter(return air to furnace) is replaced every 3 mo. or so,too. don-ohio (:^)
Jan 03, 2017 | Royal Heating & Cooling
I have a due-therm furnace in my mobile home. Model 7660001 . Heat only. What position should blower fan be on ? Summer-off-winter? It's not coming on
On winter if its on summer it would run all the time as a cooling fan . if it is not running check fuses and check the afc which controls the fan .
Nov 03, 2016 | Heating & Cooling
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Stopped heating yesterday...fan runs, but no heat... any parts available? Pretty sure is 120v ac.
Furnace Troubleshooting & Repairs ' HomeTips
www.hometips.com/repair-fix/furnace-problems.html
Nov 25, 2015 - If your heater doesn't heat or works poorly, this furnace repair guide will help you troubleshoot and fix typical furnace problems with step-by-step advice. ... If your furnace's motor runs but the blower doesn't move air, the belt that ..... a tune upbut couldn't really find any thing wrong . last night and today when ...
Furnace Not Blowing Air? A Furnace Troubleshooting Guide
asm-air.com/heating/furnace-not-blowing-air-troubleshooting/
Dec 1, 2014 - A furnace works by a very simple principle, it uses some type of fuel ...This series of heated coils (called a heat exchanger) has a fan ... Today we will address the most common causes of a furnace not blowing air, and what you can do tofix it. ... It seems like this would be a no-brainer, but I can't tell you how ...
Simple Furnace Fixes ' The Family Handyman
Jan 01, 2016 | Heating & Cooling
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
My furnace is an older type furnace and it was working fine yesterday but the blower won't shut off after it runs for a while it run continueally I was wondering what I could do to fix this pr
When you say 'older furnace' I am assuming old enough to where there is no circuit board. They will usually have a thermally activated 'fan-limit' switch with a bi-metal sensing device. Most older furnaces had either a Honeywell or a White-Rodgers controller and they look almost identical. With the furnace door off, look towards the top of the furnace vestibule (above the flame area) for a rectangular box approximately 3 1/2" wide by 5" long. Tap the side of the box with a screwdriver and if the thermostat setpoint has been satisfied and the gas burners have been off for more than three minutes, the fan should then shut off. The switch contacts are either stuck together OR the bimetal sensing device is weakening from thousands of cycles.
If it continues to run, squeeze the sides of the 'lid' of the box and remove the cover. Inside you'll see a round moveable dial with three pointers, marked 'fan off, fan on, and limit'. The 'limit' should remain at or near the 200 degree setting, the 'fan on' can be anywhere around 140 and the 'fan off' can be anywhere near 100 degrees. It is the 'fan off' position thats giving you the grief.
Turn the thermostat up again and sit there and watch the dial do its thing and yo'll understand better how this control works. Watch it rotate past the 'fan on' setting and observe the fan turn on. Turn the thermostat below room temperature and watch the gas shut off and the dial rotate back towards the 'fan off' setting. If it hangs up again before twisting past the setpoint, you can slightly increase the setting to compensate for the weakening bi-metal element. But just a tiny bit, not a great amount or you will have the fan shutting off with a lot of residual heat still in the heat exchanger. The idea of the delay in shutting off the fan is to remove all that residual heat and transfer it to the house.
There are other brands that utilized 'timed on' fan controls, and there are a few other variances of controllers but what's described above should cover the vast majority of older furnaces.
Remember there is ELECTRICITY inside the fan control and any adjustments should be done with the power OFF !!!!
Dec 26, 2014 | Heating & Cooling
Janitrol gmp gas furnace ignitor troubleshooting 125 blink
if it is shutting off abruptly the limit is either wired wrong or set wrong. If the fan comes on and blows the flame out there is a hole in your heat exchanger which can result in fire or carbon monoxide poisoning. Have an experienced tech take a look at it to be safe.
Nov 25, 2017 | Heating & Cooling
1330-1114-8745-0519-5248-9985 NEED AUTHORIZATION CODE
S/N: 1330-1114-8745-0519-5248-9985 a/n 1330-1752-4590-7863-2254-9815
1330-1752-4590-7863-2254-9815 I have tested it well. It works is photoshop cs3
S/N: 1330-1114-8745-0519-5248-9985 1330-1752-4590
this S/N: 1326-1185-6276-9982-7597-3651 worked on my cs3 ;) yeyyy!
1330-1752-4590-7863-2254-9815 (serial number ) 4372-6026-1944-2931-7644-7910-4895 (activation number)
Nov 18, 2011 | Adobe Computers & Internet
Why heater coils glow?
It sounds like you're describing one of two things. The hot surface ignitor in a gas-fired furnace, or the resistive heat strips in an electric furnace.
The hot surface ignitor in a gas-fired furnace lights the burners. This ignitor in modern furnaces serves the same purpose as the standing pilot flame did in older furnaces. It provides the required heat to ignite the gas at the burners. Without an ignition source, a gas-fired furnace cannot provide heat. When the ignitor is activated it will glow bright orange or yellow.
The resistive heat strips in an electric furnace actually provide the heat to a home or building. When the furnace turns on, the heat strips are activated and usually glow orange when they reach peak temperature. In almost all cases, the heat strips are not easily seen or accessed without removing covers or panels inside the furnace.
Feb 28, 2011 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
