Question about Grilling
How can you tell if a regulator on a propane tank is bad
    Top Expert:
  • 78,010 Answers
No gas flow when the storage tank of gas is full.
Posted on Dec 19, 2016
I have a 40000 btu all pro and it lights but the line freezes up and it starts throwing a large flame out, what is going on ?
Sounds like the regulator is bad or the tank is overfilled. The liquid propane is supposed to vaporize under high pressure within the tank, and the regulator lowers the pressure to feed the burner. It seems that your regulator is getting liquid and it is vaporizing at low pressure in the regulator. When the liquid vaporizes at low pressure it gets super cold.
Jan 26, 2014 | All-Pro Propane Garage Shop Heaters - All...
Propane was leaking between tank and regulator on my BBQ. Replaced with three new regulators and two new propane tanks but still get strong hissing from vent hole and strong smell of propane when I open...
I would recommend you take the regulator, hose and 20# cylinder to your local propane co and have them check it out for you. Or if possible, just load the entire bbg in a truck and bring it all to them. Call first to schedule a time that can look at it. If you replaced the tank and the regulator, my guess is that you probably have a cracked fitting or the fitting is missing an integral part that seals it to the tank. Douglas
Jul 29, 2010 | Char-Broil Grilling
We just got a new propane tank and connected it and propane is not coming through
Disconnect and reconnect hand tight, open slowly, if this doesn't do the trick than tank valve is bad. Another thing that could be bad is your regulator, but I would start with tank first is grill worked before new tank.
Mar 21, 2010 | Thermos QuickSet 462836203 (LP) Grill
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Gas ranges low pressue propane? 2 of them
The problem is with the tanks or the pressure regulator.. Call your propane provider and tell them what is going on. they should come out and replace the regulator and check the gas line for kinks or partial blockage.
Jul 11, 2009 | Kenmore 30169 Electric Single Oven
Cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Apr 11, 2009 | Coleman Roadtrip Grill LXE 9949-750
I have just changed propane providers and now my flame is red or orange intermittently depending on outside temperature, I have had the propane company come out and recheck, they readusted the regulator...
Did they indicate on a paper what they are getting for pressure under full-load? You should be getting between 9.5 and 10.5 inches of water column when all appliances are running. An orange flame indicates low gas pressure, not enough air mixture, or dirty burners. The intermittent condition when cooler outside makes me think that you have a bad propane regulator or too high of moisture in your propane tank. Did you change companies for price or quality of service? You may have made a bad choice.
Dec 05, 2008 | Heating & Cooling
Propane tank with regulator
You're fine using a regulator, just keeps the propane 'regulated' : ) Since you already have it, I'd try the one you have. I'd figure your regulator for the big tank is set for low pressure, really may be fine by itself, but the additional one at the Webber end won't hurt anything. This is a YMMV, try cheapest way first using what you have, not much of a problem to change to the other one if it doesn't work.
Oct 29, 2008 | Weber Baby Q Grill
Gas Grill regulator freeze
yes you need to replace the regulator it sounds as if the vent is plugged.
Hope this helps
Jun 22, 2008 | Grilling
Grilling Logo
66 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
