Question about Brother XL-5130 Mechanical Sewing Machine
Brother XL5130 sewing machine. There are two springs to the left of the bobbin case. The one on the right is unattached at the bottom. What does it attach to? Is there a way to send a picture?
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
  • 65 Answers
SOURCE: Spring unattached on Brother LS-1217 near bobbin
Check out this site. There is pictures of each machine there. All the Q&A answers in simple language, as well as a GREAT cust. support. (its a Brother after all!)
I found download manuals there as well.
I hope this helps! Thanks for keeping the Art of sewing going!!!!
Happy sewing!
Posted on Jan 24, 2009
  • 66 Answers
SOURCE: Bobbin Case
ok Sim this is a bit tricky but not to tricky first turn the handwheel toward you until the hook is at one o clock postion then slide the case without the bobbin in into the hook area you may have to work the handwheel back and forth alittle but it should slide in just remember that the case should ride in the rim. also take the needle out first that way you wont get stuck trust me it happiens.
Posted on Jan 28, 2009
  • 1066 Answers
SOURCE: Brother sewing machine vx1120 Ithink won't pick up bobbin thread
have you tried other thread and a different bobbin?  The tension screw on the bobin case could be too tight.
Posted on Mar 11, 2009
My shuttle came out and dont know how to put it back.
Hold the bobbin case with open side towards you. The thread should unwind on the top of the bobbin from the left. Place it in the case so when the thread is pulled into the slot in the side, the bobbin rotates clockwise. Pull thread to the left under the tension spring and fit case and bobbin over the central spool inside hook assembly. With the locating finger in its recess, press case home and it will lock into position with a click..
Apr 02, 2014 | Brother LS-1520 Mechanical Sewing Machine
Just got the sewing machine last night - read the manual, etc - the tension of the bobbin is way off. tried every solution mentioned, but its still not working
are you adjusting the little screw on the tension spring on the bobbin case by minute amounts each time? Only turn it a quarter turn each time you change it.
If you do the dangle test, (suspend the bobbin by the thread tail) the bobbin case and bobbin should stay still in the air, but a gentle tug on the case should release thread. Adjust the little screw with the mini screwdriver in your kit until you get it to this point. turn it left to loosen and right to tighten.
Also check that the bobbin is in the bobbin case the right way, page 12 of your manual should show this. Yout want the bobbin to turn anticlockwise when you pull the thread tail. Then load it into the shuttle using the latch on the bobbin case to secure it.
It is possible that the tension spring itself is faulty in which case you can buy a new bobbin case for the machine from the local machine shop, or
Jun 02, 2011 | Brother LX3125 Sewing Machine
My bottom thread is a real mess when I sew. The
I would suggest to replace the bobbin case,
make sure the needle is not in backwards
make sure the needle is not bent
Jul 29, 2010 | Brother BC-1000 Computerized Sewing...
My bobbin case will not stay - it turns to the
it sound like you dont have it in correctly take the needle plate off and replace the the bobbin case making sure that the bobbin case stays in place all the way to the right while you put the needle plate back on hope this helps
Jun 28, 2010 | Brother CS-6000
My Brother XL5130 tangled thread on bottom
Check to ensure that you have routed your bobbin thread properly in the bobbin case.
Mar 27, 2010 | Brother Sewing Machines
Bobbin thread won't engage.
The bobbin case is not in the shuttle.
Raise the needle to it's highest position.
Lift the lever on the back of the bobbin case and hold it open as you insert the case into the shuttle; arm on the case pointing up. You may have to turn a bit to the left or right - it will click when in place.
Mar 20, 2010 | Brother CS-8072 Computerized Sewing...
I have a Singer XL5000 machine, the normal looking bobbin is not spinning with the shaft and wont wind what have I done wrong?
Is your bobbin case holding in place right? See if you can jiggle it back and forth to see if it moves. If it does move, it may have unattached itself in it's inner-casing.
My bobbin case would just go back and forth in the casing. Make sure that your needle plate is inserted right, as it locks the bobbin case in. You may have to unscrew the needle plate, take out the bobbin case, place it back in - pushing it to your left as you glide the needle plate back into place. (go from front to back while inserting). It should catch your bobbin case and lock it into place. Hope this helps. If not I would suggest you take it in for repair. Good luck.
Jan 14, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Spring not connected behind bobbin casing
It is most likely the feed dog return spring. A cam lifts the feed dogs up and the spring pulls them back down. It hooks to the feed dogs bracket and goes straight down to the machine frame, there should be a small hook or post for it. You may be able to sew slowly without it attached.
good luck!
Nov 24, 2008 | Brother XL-5130 Mechanical Sewing Machine
Happy sewing!
Nov 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Brother XL-5130 Mechanical Sewing Machine Logo
67 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
