Hello! Aiwa AD-S10 (SD-F260) Not recording, but does playback just fine, and line output too loud.
I have a computer connected to a 3.5mm to cable to RCA connected the RCA jacks on the back. I play my music, hit record and the Rec light isn't on, the peak meters are maxed out, but the tape is moving like it should. After I'm done I play back the tape and there is no sound but static and the track that was on it before. If this helps at all, I just replaced the output resistors to a *higher value becuase it played to loud. I NEED HELP ON THIS TOO! This was my original problem before I got bombarded with a whole platoon of more! I didn't touch the input resistors though. Any help appreciated. *10K ohm (originally 2K ohm) EDIT: I switched back down to the original, thinking it might make a difference, I found a set of pots that say "PB Sens" I thought it might be "Playback Sensor", but after fiddling with it, it does adjust the line output and the peak meters. Now I think it MIGHT be "Playback Sensitivity", I turned it all the way down, but still seems to be too loud for line output. EDIT: I fixed the line output but the recording still dosn't work
2 Suggested Answers
  • 547 Answers
SOURCE: No Sound When Records are recorded to Computer via the Microphone
The mic input is for a low level source. You would likely overload it if you used it that way.
Use the "line in" instead.
Posted on May 15, 2016
Want to connect pc speakers and subwoofer to lg37lc55 tv unfortunaly it doesnt have an earphone 3.5 connection point. My other smaller tv does, the speakers and subwoofer consist of a white and red audio...
Your TV should have an AUDIO OUTPUT other than optic..at least " Headphones" output..
You can connect TV audio output with a RCA cable.
white and red audio jack....
since SUB has both RCA and "3,5mm Headphone female Jack"..here are the options;
** you need to buy a cable one end 3,5mm MALE headphone jack and the other end 2xRCA stereo (or 1x RCA for mono or you may need "Y cable " ) to be connected to your TV...
** or 2x RCA
white and red audio jack and connect from your TV..
**" "Headphones" output to SUB with 3,5 male-to-male cable ( the least recommended)
And you need to connect front,centre and rear speakers to your SUB as well...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
May 19, 2011 | LG 42LH40 LCD TV
Someone did my wedding video, it wont finalize, but plays back on the camcorder. She lent me the camcorder, along with usb cord and software. I cannot get the data from the disc to transfer to my...
Unfortunately, only video and/or pictures from your (SD Memory) Card can be transferred (via the USB cable) to your computer. Video/pictures from a disk is not accessible to your computer.
So, you may wish to try to playback the video (on the camcorder) with the output to a DVD recorder (using the AV cables from the camcorder to the DVD recorder or a VCR recorder). This assumes you have a DVD recorder (or VCR recorder) that will take the RGB input from the camcorder. Connect it up just like you're viewing the playback on a TV monitor.
Jan 27, 2011 | Samsung SC-DC173 DVD Camcorder
I have a Tascam 424 mkIII that I just got in the mail today. Keep a long story short, the playback levels are really low in all outputs. I get a loud signal sound, though. What could it be? Keep in mind...
You may have a bad impedance matching situation. Check the level at the headphone jack for starters. If that seems low, there is a problem with the playback amp, which may be the same as the record amp in that model, I'm not sure. The switching mechanism that flips the amp from record to play may be hanging up. Start with the headphones. If that's good, your impedance match is way off, or you simply are using a bad cable, as it feeds from the same amp as the outputs in most cases.
Dec 21, 2010 | Tascam Audio Players & Recorders
Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Dec 30, 2008 | Audio Players & Recorders
use tape1 record out to the Line in jack on your computer. you should then be able to record to .wav, .mp3s etc. with an audio program like Nero.
Dec 22, 2008 | Technics SUV500 2-Channel Amplifier
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Casio CTK-720 USB computer/music connection
1.Download Audacity -
http://audacity.googlecode.com/files/audacity-win-unicode-1.3.9.exe
2.buy a cable for sound input, with 3.5" connector on both sides (like
the end of mic/phones)
3. connect cable from Phones/Output on keyboard to a PC where you
connect your stereo
4.run Realtek program for sound, go to Mixer/Record and enable Stereo Mix,
then in Audio I/O click on connected device and assign Line In.
%. Now run Audacity and start recording sound,you should hear your keyboard
May 16, 2008 | Televison & Video
Horizontal lines on display but firewire and SD card work fine
Hello people who face similar problems...
First confirm whether it is a problem with the head assembly/ dirty heads.
Do the symptoms appear only on the camcorder's internal TFT side display or is it visible on an external monitor (connect using the AV cable supplied) and the EVF(electronic view finder) also.
If it is visible on the EVF, TFT Side display and the external monitor then it is definately a case of Bad video heads or the tape guide requires to be aligned or calibrated
Dec 18, 2007 | Canon Elura 100 Mini DV Digital Camcorder
51 people viewed this question
 Grubhead
Grubhead
