Question about Coffee Makers & Espresso Machines
Why is water going out the back and not in container
  • Coffee Maker... Master
  • 20,318 Answers
Something isn't connected right.
The machine is overfilled.
There is an o-ring leaking in the brewer.
So much depends on the type of machine.
Google
<make> service <city where you live>
Google
Posted on Dec 19, 2016
How do I drain water out of ice machine
Turn the water supply off to the refrigerator. After complete at the bottom of the refrigerator there is a water supply tube. Put a small container under it to catch the water, loosen the hose and let both ends drain in container.
Now go inside refrigerator, actually the freezer, you will see where the line comes into the fridge. Loosen that connection and blow air through tube. Hook that connection back up back up, hook connection on back of fridge back up, then turn water back on for supply and all should be fresh water.
PS: Don't forget to grain water out of water station on front of refrigerator.
May 29, 2016 | Refrigerators
Hi, my tchibo coffee machine display is showing bean container empty when the container is full of coffee beans.I have removed the container and made sure it is there is nothing obstructing the tube.i have...
Hello
Push "Off" on the coffee maker's control panel. Unplug the coffee maker, and allow the machine to cool down completely. Remove the coffee bean container by lifting up on it and sliding it out. Wipe it out daily with a damp cloth, and slide it back into the coffee maker. Press down on the handle to click the container into place.
Dump out the water in the water container,Wipe out the water container with a damp cloth. Refill the water container with clear drinking water.
Remove the dump box and drip tray, and empty them.Wipe each one down with a damp cloth. Open the service door and push "Press." Remove the brew group by its handle, and rinse if off in a sink with hot water. Use the key provided to unscrew the plastic pin holding the metal filters together. Rinse each one separately. Put the filter back together and dry the separate parts with a towel.
Mix a package of descaler with the water in the water container every four to six months to rid the coffee machine of mineral deposits. Plug in the coffee machine, and select "On." Select the "Hot Water" button, and position the steam valve over the drip tray. Dispense two thirds of the descaler and water into a container in 15 minute intervals by turning the steam valve counterclockwise to dispense and clockwise to shut off the flow.
Let the coffee machine heat up fully, and then dispense the remaining descaler and water by turning the steam valve counterclockwise to empty the water container. Press "Off" to turn the machine off.
If this does not work then you might require a technician.
THANK YOU FOR VISITING FIXYA
Feb 10, 2011 | Coffee Makers & Espresso Machines
Sprayer is not working, but leaks water
I think you have two problems. The leaking is old seals on either the containers, or on the other end (the machine). Try replacing them. There are various part websites for these.
The problem with the spraying could be the belt that turns the pump. Check it. If it's there its probably not it. The next thing could be the little plastic tubes that go to all the componets inside the machine tend to accumulate buildup. Make sure they are all flowing free. Next try the heating element (its inside the handle area) take it apart and clean it. If all those things are checked and it still doesnt work, it might be what was wrong with mine. The all on one container that holds fresh water and dirty water has a leak. I found mine would spray correctly if i had the lid off the container, and as soon as i would put the lid back on it would stop spraying. I found out that The suction going through the container to **** the dirty water in was also putting a suction on the clean water bladder which caused the water to stop flowing out of the clean water bladder. I ended up getting an all new container with bladder because i could not get anything to seal right due to its age and warpage of the plastic. So to determine if yours is the same issue. Just take the lid off the container and then try to spray water. It may take 10 seconds to get all the tubes primed again because the suction will actually **** all the water back up to the container. If you dont want to replace the container, just spray a few passes with the lid off, then put the lid back on to **** the water back up. Hope this helps. I might not write clearly for everyone to understand, but i hope it helps someone.
Mar 01, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
I have an indesit is70c condenser drier and it doesnt seem to be collecting all the water in the water container. some seems to make it into the container but then the rest just sits in the container...
To take the lid off, remove the two screws at the back and slide the lid backwards. If you try to lift the lid up, you will break the plastic catches. I learnt the hard way. If you do it correctly, it's easy.
At the back of the tray that holds the water container there is a small hole which allows access water to drain back down into the pump. Clean this hole(it will probably be full of fluff and hair). While you are there, there is two tubes at the back off the drier the thicker on of the two is the one that the access water drains into, make sure this is not split(mine was and I used self amalgamating tape on it to seal it again.) Replace lid, replace water collector, job done.
Jan 19, 2010 | Dryers
Add water
There is a floating magnet in the side of the water fill container. Make sure the magnet is floating. That is how the Keurig determines whether there is water in the container or not. If it isn't floating, the machine thinks the water container is empty. If it is not working properly your only option is replacing the water container (or rigging the magnet and being very careful to make sure the reservoir never runs dry).
Mar 28, 2009 | Keurig Special Edition B60 Coffee Maker
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer
I have a 15 year old sub zero refrigerator. The drain hole keeps freezing up and ice is building up under the produce drawers. There is also a smell that has accompanied this problem. We have melted the ice and forced warm water through the tube to clean out any blockage but it keeps freezing up. Can you help?????
Oct 30, 2008 | Refrigerators
My new GT300 won't prime.
I fixed mine! The idea here is to help fill the tube inside back up with water. The unit may need a little help to get the suction going.
Preparation: Set the unit so you can easliy reach the back side of the unit. Fill the container with 7 - 14 oz of water and have it nearby. Place a cup underneath the coffee drip container in the front. Have another small cup of water handy.
Process: Plug in the unit to an outlet. Hold as much water in your mouth as you can. Press the CLEAN button on the unit then put your lips over the water inlet valve on the back of the unit. Force (blow) the water from your mouth into the inlet valve. You should begin to hear the unit pushing the water through. Place the water container over the water inlet valve after you have released the water from your mouth. The unit should continue to empty the water container. Now, you just have to fill the water container and make a cup of coffee.
This is the same procedure I performed to get mine going again; I am not trying to make you look like an idiot.
-Richard Barrett
Mar 16, 2008 | Black & Decker GT300 Coffee Maker
Titanium plus stuck on rinsing cyle
go in the menu remove rince cycle after it say ventilate put water in container start machine open valve it should ventilate if it doesnt remove water container take turkey blaster put water in it put the blaster in the hole were the water container goes force pressure with the blaster at the same time open valve you vented by now put cointainer back fill with water enjoy thanks for using fixya pierre
Feb 10, 2008 | Gaggia Titanium Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
