SOURCE: DS6708 symbol scanner freezes keyboard
Have you tried taking the battery out of the scanner and then reinserting it? THis should reset the scanner to some degree.
It really depends which barcodes you scanned in the manual.
Your best chance seems to be a reset to the original settings, for which you may need to look at the manual.
SOURCE: 7837 NCR barcode Scanner (RS232)
You can download the pdf from NCR.
http://www.info.ncr.com/Point-Of-Sale/Browse-Search/eRetail-FPS-BrowseBy-ResultsMV.cfm?pl=Retail%20%2D%20Scanners&PID=&title=&release=&cat=&bu=atlanta&sbrn=3&mvc=7837
SOURCE: Motorola HC700 Scanner Software
As far as i know Datawedge will work with the scanner, DataWedge provides a convenient mechanism for non-scanning awareapplications to receive data from embedded or connected datacapture devices. It allows the user to capture data into anyapplication that accepts keyboard input. It supports four types ofData Feeds: Barcode Scanners, RFID Tag Readers, MSR Readers andSerial Data Input. It provides user with text/hex data formattingand prefix/suffix facilities. Description
If for some reason the software doesn't work then have a look here @ Redbeam >>>>>>
http://www.barcodemegastore.com/catalog/redbeam/
Good luck and if you need anymore help please post back.
SOURCE: MS9535 BT Bluetooth Wireless Barcode Scanner mac
The MS9535 BT Bluetooth Wireless Barcode Scanner will enable you to connect bar code data without being tied to your mobile or desktop computer. It is an ideal solution for a number of application which include the different point of solution, warehouses, it is having a serial magic which will allow the MS9535 to work at virtually any device.
Assurance Wireless
