Hi. I was in the middle of an embroidery project when the power failed. Do i have to do the whole thing again or can i pick up where it left off? Thank you
Brother SE400 is my machine
  • Televison & ... Master
  • 20,439 Answers
Plug it back in an see. If there is a battery backup and you see 'Resume', then yes, if nothing, no you have to start again.
You may be able to do part on scrap cloth and when you get to the point where the power failed, pause, and swap in the original piece?
Posted on Dec 19, 2016
When I embroidery bobbin jams
Please you buy a new model embroidery machine.
Jan 01, 2014 | Singer 5050 Mechanical Sewing Machine
Machine embroidery needle changes position
truthfully I think their something wrong with the computer in the machine because
the bobbin locked up. sometimes when a sewing machine jams it can make
the machine jump time.
but the needle moved positions, some part of the machine is changed during the
jam up, even tho you reset it.
embroidery machine are expensive, my suggestion is to have the machine checked
Apr 05, 2012 | Sewing Machines
When we turn the unit on...it stays on for about a minute, then the picture shuts off...sounds stays on a bit longer, then the whole thing turns off.
Hi.
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help in solving the problem....
Jun 27, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
EMBROIDERY STOPS IN MIDDLE OF DESIGN. PRESS RUN AND IT WILL RUN FOR A SECOND AND STOP AGAIN
Are you sure you are not "double-pressing" the Start/Stop button? The machine might think you have said Go and Stop straight after? Try embroiderying using the foot pedal - see if that works for you. I guess you are aware that the machine will stop for thread colour changes. Do an experiment on any old piece of fabric - load the design and press the Stop button (not the one mentioned above, but the one of the left-hand side above Fix). The light should go out. This will eliminate the colour changes - the design will sew out in one single colour only. See if it keeps running and completes the design.
I would also "park" the embroidery arm, turn off the machine, remove the arm, replace the arm, turn machine back on and try again. Sometimes it just needs to start all over to get things back on track.
Jun 14, 2010 | Husqvarna Designer I
My Janome 10000 stopped in middle of embroidering a design and the machine rebooted. it was making a bit of a whining sound as it was stitching just at the last..but now the hand wheel seems harder to...
Janmore10000 Stopped Embroidering thenstopped everything just shutting off.
If it is getting no power at all, it is probably a fuse. Thefuse is located in a little black box underneath the base of the machine, butit is NOT an easy job to take the box out, disassemble it, replace the fuse,and then reassemble the whole machine. But in your comment you mentioned that there is power tothe machine that means its not fuse problem.
It stopped embroidering in the middle of a project. the handwheel would notmove at all this means that it wasthread jam. Also check the carriage carriage if it does not move to the rightor left and gor stuck in one position or hardly moving a bit then it is out of calibration.
if your machine is outof calibration it will need to recaliberate . Something is like forcing theneedle through a thread jam would cause this. This is not an expensive repair.But a time consuming repair. Its advisable to get it done by service center,
click this linkdirectly to get the support center help
http://janome.com/index.cfm/ContactUs
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Nov 29, 2009 | Janome Memory Craft 10000
430 will not recognize wembroidery unit.
I am the person who posted the solution about too much stabilizer. Unfortunately that did not solve the problem in the long term. I spoke with the Bernina dealer and found out that the sewing machine needed to be recalibrated. I found out how to do this from my user manual and the problem appears to be solved for now... hope that works for you
Jan 12, 2009 | Bernina Activa 140
56" sharp 56dr650 rear projection tv
Hi - wanted to let you know that I have the same problem and I contacted Sharp (800) 237-4277. They offered me a prorated exchange. Select #1 prompt for Operations and then they will create a case number if you don't already have one and then send you over to the Disbatch Dept. They are picking up my 56" TV and are selling me a LC52"D65U for under $450 current retail value of the new TV $1900. Give them a call and see if they can work out a deal for you too. The whole transaction will take 7 - 10 days. Good Luck!
Dec 10, 2008 | Sharp 56DR650 56" Rear Projection HDTV
Samsung projection tv
Unplug it and plug it in again. This worked for me and I have a very similar problem occasionally. Turning the power off and on with the remote will not work.
Oct 20, 2007 | Samsung SP42P2S Television
Wont turn on
Hi ,your trouble could be a 2200 35v cap on the high voltage power supply,its in the middle of the board behind a little u shaped heat sink,the cap is green and if its bad the top will be pushed up,hope this helps
Oct 14, 2007 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
