Question about Refrigerators
How to replace a lighting bulb in Proline TPF133B fridge/freezer? Thanks
bobotfel
  • 236 Answers
SOURCE: fridge and freezer not working after powercut
Check your voltage.
Posted on Jan 02, 2008
bobotfel
  • 236 Answers
SOURCE: FREEZER SECTION WORKING OK, FRIDGE SECTION NOT WORKING
Check the vents of your fridge side if present, if no air then may be your blower not working or some ice formation that blocks the air(try defrosting). Check also your vents for obstruction or overloaded with stocks.
Posted on Jan 26, 2008
  • 958 Answers
SOURCE: Kenmore refridgerator 78285892 Freezer light won't work
probably a bad socket. 10-12 years old metal would not likely to last inside a freezer box.corrosion could have eaten the metals...
Posted on Feb 12, 2008
Illeagle
  • 525 Answers
SOURCE: proline pc178a fridge freezer still
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided.
http://www.repairclinic.com/0088_4_1.asp#Level1_1
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Unfortunately, we can't describe all of the possible problems and repair solutions here. If you are unable to troubleshoot the problem from here, you may need to contact a qualified appliance repair technician
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 05, 2008
SOURCE: Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
Posted on Jul 22, 2008
Fridge light bulb
Not sure how the light socket only has 6V supply? The bulb for this fridge is a pretty standard 15 Watt/230V SES lamp. If you are sure the current lamp is OK I would suggest the door lamp switch has issues. Try pressing and releasing the door switch manually and check that it functions ok without getting stuck or any sluggish movement. This action in itself may fix the problem.
Jan 18, 2014 | Miele KFN8462S Bottom Freezer Refrigerator
Light not working in Maytag Plus 134A Refrigerator
Sure you've got power to the bulbholder? Check the switch
Sep 04, 2012 | Maytag Refrigerators
My proline fridge freezer not cooling
I have the same problem with a proline plc 190w fridge freezer not cooling in the fridge compartment please help it's my mums and she can't afford a new one , thanks in advance
May 19, 2012 | Refrigerators
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Fridge is freezing food
YOU HAVE A BAD THERMOSTAT,REPLACE,MAKE SURE DRAIN IS CLEAR TO,THANKS-MIKE
May 07, 2008 | Candy CPCA240FFK Bottom Freezer...
BUZZING NOISE ON WHIRLPOOL GOLD FRIDGE/FREEZER
YOU MAY HAVE A BAD LIGHT BULB, SOCKET OR LIGHT SWITCH. TRY WIGGLING THE SWITCH TO SEE IF THERE IS ANY CHANGE IN THE BULB INTENSITY. IF NO CHANGE, TRY REPLACING THE LIGHT BULB. IF NO CHANGE, THE SOCKET NEEDS REPLACED.
Apr 08, 2008 | Refrigerators
Jan 22, 2008 | Freezers
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
