Question about Samsung Series 5 60-inch PN60E550D1FXZA 1080p 3D Plasma HDTV with Two Pairs of 3D Glasses
Pn60e550d1f powers on but the screen does not light up, I have sound when I press buttons thats how I know the TV is on.
3 Suggested Answers
SOURCE: tv turns off
Hi there, my husband fix the problem. My small son had changed the settings for the HDMI. My husband switched the tv to DVD mode started a dvd & changed all the settings back. After changing all the settings he also reboothed the setbox machine.
Posted on Apr 14, 2008
ginko
  • 19396 Answers
SOURCE: I have a Samsung S5053
Hi.
The TV must obviously be tested and repaired, as it is faulty.
The ticking sound and the beep make think to a faulty PSU or to a defective main controller board.
The PSU is indeed the first culprit, but the part must be tested jumping control lines with live power to test higher voltage. Unless burnt areas or blown components (eg capacitors bulged or leaking) can be spotted at a glance on PSU board, the part must be tested, test is complex and pose safety issue. For this reasons the unit must be tested by a technician.
Here all parts for this set.
Here PSU: PSPF501A01A SAMSUNG S5053
Posted on Aug 13, 2010
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
Nov 11, 2015 | Samsung UN39FH5000FXZA - 39in 1080p 240...
Sony kdl52xbr9 it comes on i can see picture and sound for a couple of seconds, then it shuts off and blinks 6 times
Hi! and Welcome to Fixya!
Blinking red lights on the tv are error codes that explains hardware issues on the tv.
However, if after turning ON the tv and you will see the Sony logo on the screen before the picture goes off and then flashes red lights for a number of times, this could mean that tv can still be recovered. Try the option below to isolate possible issue with settings that cause your tv to shut off. Disconnect first all external devices from the tv
1. Turn ON tv first and wait until it flashes the red lights > press and hold down the UP Arrow button ( use remote control ) > while holding down the UP Arrow button, press the POWER button on the tv > tv turns off, wait until it turns on by itself > release the UP Arrow button when tv turns on
Note: reset is successful when you see a welcome screen on the tv and ask you to select your Language. This is the Initial Setup, just follow the on-screen instruction
If that solution did not resolve the issue then a service may be recquired.
Let me know if this helps!
Oct 27, 2015 | Sony Bravia Kdl52xbr9 52 1080p Lcd Tv...
My 42 inch philips (42PFP5532D) has blank screen but blue light to show its on but nothing on screen :(
just let me know if their is a sound when you turn on the tv then the only problem is black screen. if you can get sound tried to press the channel up/down button let see if you can get a channel. if you hear that receive channel that was mean the problem is either the screen back light get busted or the power inverter is defective. hope this can help good luck.
Nov 02, 2012 | Televison & Video
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
I have a Philips 52PFL7422D/37 52" TV. For the last year now the TV will make a clicking sound like it is turning on but never does. After a couple of seconds to a minute the TV makes another...
I have the same model and the same problem... I am told the power display board is is the issue and may need to replacing. New board costs around $80,or a bad capacitor depending on your paitence.
Nov 23, 2010 | Philips 52PFL7422D/37 TV
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Black screen and no sound
I had the exact same problem with my Magnavox TV. No sound and no video but the power light was lit. I finaly gave up on finding a solution on the web and called in a repair tech. He fixed my TV in less than 30 minutes. You can find the solution here.
http://www.magnavoxhelp.com
Jun 16, 2008 | Philips Magnavox 9P6034C 60" Rear...
Samsung Series 5 60-inch PN60E550D1FXZA 1080p 3D Plasma HDTV with Two Pairs of 3D Glasses Logo
63 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
