Question about Dayton Heating & Cooling
I have a Dayton heater number 3E634 it was used on natural gas what do I have to do to put it back on propane
  • 2,854 Answers
You will need to contact the manufacturer of the product, or find a store that sells and services these.
The difference is the "orifice", which is the part that the gas comes out of inside the machine, that has the flame burning at that area.
Orifices usually screw in , and have different size holes in the center of them for the different gasses.
The two kinds of gas use a different orifice because of the different pressures and flammability.
God bless your efforts.
Posted on Dec 19, 2016
Model #3e243b Dayton heater chg from LP to NG
Dayton is primarily sold by . You must purchase a re-jetting kit (Natural Gas Valve) from them to accomplish this.
Grainger Part # natural-gas-valve-1fek5_as01.jpg view_larger_button.gif Natural Gas Valve
Item # 1FEK5
Natural Gas Valve, For Use With 5VD61, 5VD63, 5VD65 DAYTON
1FEK5 4401 Usually ships
1-3 Days 1 $144.30 item_sale_symbol.gifSale Price$115.44 See All: Parts
Sep 23, 2011 | Dayton (3E379) Heater
Convert to propane from natural gas
To see if you can get a conversion kit for that heater, you will need to contact grainger which sells the Dayton brand exclusively...
Apr 22, 2011 | Dayton 3E375 Gas Heater
Is there a kit to change from propane to natural gas for a Daton model # 3e239e unit heater. I have talked to Graingers and they don't know and they say the unit has been discontinued. If there is can you...
Bill, the model number is good, but won't get anybody the part number of the gas valve. Basically, there are 2 issues to address, the pilot orifice size and the pressure regulator. Get the numbers off of the gas valve (OEM numbers, brand) (likely White-Rogers or Honeywell), and search via manufacturer for conversion kit. (Generally a spring and a pilot orifice). Should you locate a kit, be prepared to have someone properly adjust the manifold pressure once installed. Also, as the make things cheaper, sometimes they are built for one fuel or the other and sealed. You may end up buying a new gas valve. Being raised in a propane plant, I recall their skill-set far superior to general HVAC guys (like myself) in this arena. As propane conversions are a part of everyday life for them (temporarily making a furnace run on propane during construction and switching over once the gas line is hooked up), they are probably a good starting point!
Dec 03, 2010 | Dayton (3E379) Heater
Dayton 3e229 ser#c8 706069
You can use a universal gas valve such as VR8200 from as long as you get the correct gaas (Natural or Propane) Have them cross reference tha valve.
Feb 26, 2010 | Dayton Heating & Cooling
Natural gas convertion to LP
you need too change the orfice about 10.00
Dec 22, 2009 | Dayton Heating & Cooling
I have a dayton heater and need to switch it to propane from natural gas, i cant find orfice or the spring anywhere to buy them is there somewhere to buy these parts? the model nuber is M-3e404, and the...
Call this number 1-800-323-0620 That is the Grainger Parts line. The Dayton units are all made for Grainger.
They will be able to tell you (1) if the unit can be converted.
(2) If the parts are available to convert that unit.
(3) You will also be able to order the parts directly from them if they are available.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 08, 2009 | Dayton Gas Furnace Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Want to change Dayton 3E133E from natural gas to Propane
Would have to have conversion kit IF available. Must get from mfr. The Dayton brand is owned exclusively by W.W.Grainger. Not sure if someone else makes their furnaces for them. Start w/ Grainger, if they won't sell to you maybe they will give you the name of a company who will work on it. Good Luck!
Mar 09, 2009 | Dayton Electric Heater
Physical difference between natural & propane orfice
Merry Lynn, there will be no physical differences between Natural Gas heaters and Propane Gas heaters. Check the model number of the unit, it may have a N or P or LP printed at the end of it to distinguish which gas it uses. The plate that is attached to the heater should indicate the type of gas it uses.
DO NOT try to convert this heater to another gas.
Oct 16, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
