Question about LG VX5200 Cell Phone
VX520 I accidentally changed a setting and now when I try to go into setup it immediately goes back to welcome screen. There is 0 idle time between screens
Verifone vx520 tamper please enter pasword
if you have a tamper you may need to get it replaced, try this press enter key and if it takes you to a menu press set up, enter password, do you have the password? 1 alhpa alpha 66831 ( the alpha key is above the 2) then press more until you see date and time, change date and time see if this fixes tamper or press red x until you get antoher screen or press f2/f4 same time enter password and then clock change time if this does not work you need a new terminal
Jul 22, 2014 | VeriFone VX510
Hp pavilion all in one AMD goes to sleep after 1 minute idle then asks for password to open up.. how to extend idle time to 2 hours
What you are experiencing isn't "sleep" mode, it is the screen saver. If you have WINXP, right click on a clear area of the desktop, and select "Properties". When the DISPLAY PROPERTIES window appears, select the "screen saver" tab. Change the "WAIT" time to the time you wish the scrren saver to delay. If you don't want to have to login after a screen time out, uncheck the "On resume, display Welcome Screen" box.
Nov 27, 2013 | HP Black Pavilion 20-b013w All-in-One...
Goes into sleep mode will not come back on for 2 weeks or longer
It might be setup to go into sleep mode if it is left idle for a certain period of time. To change the settings click the following(I am assuming you have windows vista or windows 7):
Start,Control Panel,Power options,Choose when the computer goes to sleep(look on the left side),Then adjust the settings to what you wish by clicking the black arrow there.
Also check the "choose when to turn off the screen" in the same spot you clicked Choose when the computer goes to sleep.
Nov 10, 2010 | Dell Inspiron 1525 Notebook
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
I have a compaq presario sr1103wm and it won't load windows. i turn it on and it goes to screen saying windows wasn't shut down properly and lists the options: start in safe mode, with networking, with...
re install or repormat your system to fix all problem will return into normal operation... but before that dont forget to save your data if you have important data dont'want to loss it..
if can't open the program or operating system remove your Hdd then insert into another computer to back up the data ot be sure that you have back up all important data. except those programs cant make back up... you need to re install again from the source..
Sep 17, 2009 | Compaq Presario SR1103WM-B (PC183B#ABA) PC...
Need to reset password for verifone omni 3740
If you press the F2 and F4 buttons and enter 1 Alpha Alpha 66831 and the terminal goes back to the idle screen then the system password has been changed or the battery is bad in the unit and will have to be replaced. Either way it will have to go to a repair facility to be corrected.
Aug 12, 2009 | VeriFone Omni 3700
Hey
Is this for watching videos? If so then the first time you watched a movie on ps2 you had to enter a 4-diget code. That is the code for watching movies un less you some how change it through the settings. If you don't remember the code try changing ti through settings. Other than that you could call sony playstation or try every possible number. (You might have just clicked x 4 times when this happened for the first time and accidentally set the code to 0-0-0-0 I accidentally did that.
Aug 17, 2008 | Sony PlayStation 2 Slimline Console
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
LG VX5200 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
