Question about Microwave Ovens
Changing light bulb on Gaggenau EB194 oven
We cannot get the lamp cover to unscrew to change the light bulb
  • 958 Answers
SOURCE: Burned out light bulb
can u open the housing?. you can look at the spot where the light is and you can see a bulb holder screwed on the metal housing. it has two wires hooked up to that holder. remove those wires and unscrew the holder of the bulb. look closely at the bulb if it is fiited to the holder like an ordinary light bulb. if its like that then you can unscrew it and replace it. if its not screwed to the holder then you have to buy the whole bulb assembly at the dealer of your microwave. it is considered a special bulb only from the dealer you can get. i hope i was able to solve your problem..
Posted on Feb 18, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replace light bulb on Whirlpool GMC305PDS07
You'll need to remove the outer cover (wrapper) to get to the bulb.
On an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Mar 06, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Service manual for Panasonic NN-SD466M microwave
Panasonic's UK site is here, and you can use the support links to find spare parts and servicers.
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
Many models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
Posted on Aug 30, 2009
  • 2468 Answers
SOURCE: need to change the light bulb. found it but can't
push in on the bulb and then turn a quarter turn counter-clockwise,its a bayonet base bulb,not a candelabra base like a typical light bulb has
Posted on Jul 26, 2010
HOW DO i CHANGE THE BULB IN MY SHARP R-651ZM MICROWAVE OVEN
Changing the light bulb on your Sharp carousel microwave will allow you to have needed light inside the oven. Microwaves are not designed for consumers to change the light bulb due to manufacturer liability, but it can be done. Following the proper steps will ensure a successful installation. Step 1 Unplug the Sharp carousel microwave from the electrical outlet.
Step 2 Locate the screws around the outer cover of the Sharp carousel microwave and unscrew all the screws.
Step 3 Lift off the covering.
Step 4 Locate the bulb and unscrew. Screw in your new bulb.
Step 5 Replace the cover and screw back tightly. Once done, test your new bulb.
Oct 10, 2017 | Sharp Microwave Ovens
Change the light in my microwave oven
If the light. Is covered remove cover unscrew bulb and replace .take bulb and compare with new one
Jun 17, 2017 | In Microwave Ovens
How to change a light bulb in microwave
Things You'll Need
30-watt incandescent light bulb
Screwdriver
Light
Unplug the Magic Chef microwave from the wall outlet.
Remove the screw from the light cover located on the left side of the underside of the microwave. The light cover is connected to a hinge and will lower, but cannot be removed from the microwave.
Unscrew the light bulb, then screw in the new light bulb. hope this helps
Oct 08, 2016 | Magic Chef Microwave Ovens
The lightbulb cover on my whirlpool WFE361LVS wont unscrew, how do I get it off, I need to change the bulb
Most microwave ovens lamps' outlast the life of the microwave. So, most of them do not have access covers for the oven lamp. The lamp has to be replaced from inside the unit. Also, the newer units tend to use bulb assemblies rather than just a screw in type bulb. Call Whirlpools 800 help line or your local appliance parts store and have them look it up for you.
Sep 19, 2013 | Microwave Ovens
How do you change the light bulb in a panasonic microwave model nn-st657w
Switch off power ,Remove the top panel cover and the lamp will be visible within. Now unscrew the lamp cover and remove the lamp . check for failure and replace with the same wattage and thread.
Jan 10, 2013 | Microwave Ovens
How to change bulb in five star convection oven? Bulb covered. How to remove cover?
Remove the outer cover by unscrewing the fixing screws. The lamp will then be visible for replacement.
Mar 21, 2011 | GE Advantium 120 Convection/Microwave Oven
HOW TO CHALGE LIGHT BULB
disconnect the oven from power supply. If the lamp of your microwave is in the most common location, you will need to open the oven by unscrewing the screws on the rear. You will see the lamp behind the control panel. remove and replace the bulb
Jan 12, 2010 | Goldstar MA-1011 Microwave Oven
How do I change the light bulb in the microwave - the one that shines above the stove? I removed the covering and tried to remove the bulb but it doesn't seem to unscrew and the bulb just came out - no...
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "how to change cooktop lamps" for example.
Nov 24, 2009 | Roper MHE14XKB Microwave Oven
Changing light blub of oster microve oven
The lamp is located under the stainless top cover of the microwave which unscrews from the back and sides, the bottom corners in the back have special torx screws which are meant to thwart you from removing them but a pair of locking pliers does the trick. Then under the cover on the top of the microwave there's a black elliptical shaped base with only 1 screw holding it down, that is the lamp. Pull the female spade connectors from the lamp, unscrew it and take it out. Oster has about the worst customer service around so i have not verified that they will sell a replacement lamp but if you can find a 20W 120V replacement with spade connectors that will do.
Jan 15, 2008 | Microwave Ovens
Where is the light bulb located?
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
