I did everything it said and the volume worked so I figured t as food. The guide channels will not work
5 Suggested Answers
machinehead2
  • 14 Answers
SOURCE: I have a new TV
Usually on a universal remote (after programmed) the volume is controlled by pressing the cable button then adjusting the volume. When you turn your tv on by pressing tv power---then flipping through the channels by pressing cable--channel up or down. The remote (in my experience usually only controls the volume while in the cable mode)
Posted on Jan 10, 2009
SOURCE: remote not responding for dvr,guide, faast forward, stop, ok, etc. only works for up/down volume and channels, and digital input of channel.
Sounds like the remote needs a clean underneath the buttons.
Posted on Sep 25, 2012
ercupa190
  • 12223 Answers
SOURCE: Can't change channels, get to guide, or list. Only function working is turning on/off and volume. Please help, is has never happened before
reset the code again, and try it.
read your instr. manual very well. 2) change by new batteries alkalines full charges 3) retight the springs terminal batteries with long pliers for better contacts 4) try to open the remo control for clean the keypad from dirty, oxide, corrosion, or bad contacts. and test again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Posted on Oct 02, 2012
  • 2559 Answers
SOURCE: On mx900 genesis universal remote the up down arrows to change channels will not work - cannot get guide to display -cannot change channels using#key pad - volume up down work fine suggestions?
Incorrect code. Try different programming codes for one that operates your TV correctly. Note not all universal remotes will work all features of a tv. Sometimes all you can get (especially on lower end remotes) is power and volume
Posted on Nov 01, 2016
Nov 01, 2016 | Televison & Video
Program directv remote to do everything to Proscan 43LA45H
It may not control all functions for tv ,only on,off , vol, not menu auto program... try www.directtv.com .
Sep 26, 2014 | Proscan 42LA45H 42 in. LCD TV
Microwave will not heat food everything else seems to work, timer, rotating plate everything works but heating food
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
=0=0=0=0=0=0=0=0=0
Sep 14, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a new TV Model 47PFL3603D/F7 and am hooked up to comcast digital box and cannot figure out how to get my comcast remote to regulate the volume. I have the set on channel 3 and everything works...
Jan 10, 2009 | Televison & Video
Picture within a picture on screen
Click here to find info the user's guide and how to turn close caption OFF. Download all the files and and you should find the info on page #19 but you will need to have the TV remote control or if your TV has a menu/set up button on the front panel, you can try to get to close caption using the channel up/down and volume up/down.
Good Luck.
Oct 10, 2008 | Sony KV-35V35 TV
No freaking signal
Double check ALL your ant wire connections. Then reprogram the converter to check for stations again. If that doesn't work then reposition your antenna and reprogram again.
May 21, 2008 | Insignia Digital-to-Analog Converter for...
Digital Tv stopped working
I have got samsung 40 lcd is working fine but dtv got stuck on one channel. Its not moveing from one channel I have tried everything. Its not workig. please can you email me your suggestion to solve this problem.
Email address: fazalhareef@yahoo.co.uk
Dec 15, 2007 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
