Question about Hardware & Accessories
Intertek3075048 plug in mechanical timer model: TM- 011 manual
Need Westek model TM074 timer manual
Google, ever heard of it?
The 2nd, 3rd, and 4th item in the google search are the TM-074 timer with different brand names.
Google
Nov 09, 2016 | Hardware & Accessories
Need instructions for Living Solutions 24 hour timer model tm-011
1) Closest timer manual I have to match that timer is the Sunbeam:
http://waterheatertimer.org/pdf/Sunbeam-61048-countdown-timer.pdf
2) Add comment and say what part of instructions work, and what is different for possible additional help.
3) Attach photo of TM-011
Dec 24, 2012 | Hardware & Accessories
Lost manual for timer tm-020
I have extensive files on timers, but nothing showing TM-020, TM 020, TM 20, TM2 TM-2 etc.
TM prefix is used by Woods, First Alert, Buffalo, Hydrofarm, Steyele, Utilitec and Westek.
I will enjoy helping identify your timer.
1) Add a comment and post photograph of your timer so I can identify and locate manual.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
2) Add a comment and fully describe timer in detail, and I will look for same-similar product and manual.
3) Open following page and find same-similar timer, then add a comment and say which resembles your timer.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment with your experience so others with same problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 27, 2011 | Woods Hardware & Accessories
How do you set the timer in fifteen min. intervals? Especially when there are 4 pegs?
1) You need a timer that breaks 24-hour day into 15 minute intervals.
Hampton timer and other timers with movable trippers cannot be set for 15 minute intervals.
2) All mechanical plug-in dial-type timers have 1/2 hour intervals or more
a) For example Woods 59366: sold at Lowes as Utilitec 0148297 or Target as Westek TM series
http://waterheatertimer.org/Woods-timers-and-manuals.html#59366
b) Or GE 52012 sold at Home Depot
http://waterheatertimer.org/GE-timers-and-manuals.html#52012
3) If you want 15 minute intervals, you need digital timer.
a) For example GE 15091 sold at Home Depot
http://waterheatertimer.org/GE-timers-and-manuals.html#15091
b) Woods 59377 sold at Lowes as Utilitec 015671 or Target as TE06
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 30, 2011 | Hampton Technologies Brinks Timer
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Dec 17, 2010 | Woods Outdoor Lighting Timer
I need instructions for outdoor timer model TM-104 E227659
There are two different TM-104 timers that show in web search.
1) Buffalo TM-104 sports timer
I don't have information on Buffalo TM104, or a manual
2) Westek TM104 208 to 277-Volt 4HP timer is sold by Amazon:
http://www.amazon.com/Westek-TM104-277-Volt-Hardwire-Mechanical/dp/B002YGS6TU
I don't have a manual for Westek TM104 but can help you decipher your manual.
Also you can scan your manual into pdf format, post manual on your website for free, and then add a comment to this thread so other can enjoy your generosity.
There is one answer on fixya that says E227659 timer is Woods 59403
http://www.fixya.com/support/t6189563-need_instructions
Open following link to identify Woods timers.
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
Add a comment with more information about your timer, for example brand and appearance so fixya can narrow down correct answer for do-it-yourselfers seeking free information.
Dec 09, 2010 | Woods Outdoor Lighting Timer
How to program TM 020 digital timer?
I cannot find TM 020.
TM is a Woods timer prefix.
Many Woods timers have more than 1 number depending on who packaged and sold timer.
You might be able to recognize timer from the photos shown on link below.
Following page has Woods timers and manuals.
Nov 28, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
My automatic timer is not working.
You posted under Intermatic raintight timer.
Add a comment with your model and brand and I have extensive files on timers.
The best diagnostic is the manual override.
1) Click manual override and see if Load (lights, fan, motor) come on.
If manual override clicks on-and-off crisp and clean, but the lights do not come on, check your electric power.
If the manual override does not click crisp and clean, then the timer may be rusty, or timer may need to be replaced. Buy replacement timer and swap out timer mechanisms without changing the box.
If the manual override works fine, and Load turns on-and-off with manual override, then the clock or trippers are next suspect.
2) Check if the dial is turning as time passes.
If the dial is not turning, then the clock motor is bad and you can buy a new clock motor.
If dial is turning, and manual override turns Load on-and-off, then the tripper pins might be worn out, and you can buy new trippers.
3) To buy replacement parts: Timer door has model number of timer. Timer clock located on back of timer mechanism has identifying numbers. You can snap out the timer mechanism using metal spring locate top inside box.
Grainger sells trippers and motors:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Aplus sells motors:
http://www.aplussupply.com/intermatic/timermotors.htm
Intermatic sells motors:
https://www.intermaticstore.com/ASPI700W.pgm?task=menucntrl&menuopt=TM
Nov 10, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Hardware & Accessories Logo
65 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
