Question about Kenmore Dishwashers
I have a Kenmore Dishwasher. It fill's with water and then does nothing on random cycles and sometimes days between episodes. If you open and close the door and press start it will start washing.
  • 249 Answers
SOURCE: Kenmore 665 dishwasher washing light stays blinking
could be faulty outlet pump
Posted on Nov 28, 2007
SOURCE: Kenmore Dishwasher does not wash
my problem is the motor hummms for a minute or so and turns off. Could this be the capacitor? how do you test a capacitor?
herb
Posted on Jul 14, 2008
  • 3 Answers
SOURCE: Dishwasher fan fills with water
Well, I just took my hose out (pulled both ends off the connectors) and it was indeed full of junky cruddy muck, so blew it out over a waste bin until it ran clear through. Now I've put the hose back on and will see what happens next wash!
Posted on Oct 22, 2008
SOURCE: noisy dishwasher
i have aloud buzzing nose and humming what is the problem
Posted on Nov 26, 2008
SOURCE: Kenmore HE3 front load washer F11 code
my he3 has f-11 problem also i'd have this machine for about 3yrs. the cure i found that worked was to smack the top with a hammer and now it works fine. i'm not kidding .
Posted on Dec 03, 2008
Kenmore dishwasher does not clean
Hi
First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Aug 04, 2009 | Kenmore Dishwashers
Dishwasher wont take water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 12, 2009 | Kenmore 24 in. 15252 / 15254 / 15259...
Kenmore Elite dishwasher not cleaning well and leaving dark stains on the dishwasher walls. water pumps in to correct level and pumps out. First cup of soap the water is just warm. Second up its hot and...
Check the following to address this issue
1. No water
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jun 04, 2009 | Kenmore 24 in. 16049 Built-in Dishwasher
My dishwasher sounds like its working but when i open it nothing
1. No water
2. Not enough water
May 30, 2009 | Bauknecht 24 in. GSX7551 Built-in...
My Kenmore dishwasher's basin fills up with water by itself!
the problem is the water valve, we had to replace many ruined floors in our hotel because of this, when calcium builds up in the water lines of your house and a chunk breaks free, it sometimes gets in the water valve holding open the diaphram open ever so little, but enough for water to get thru, sometimes it will pass thru, other times it won't. and if you use it everyday you won't notice it, but if it sits for a few days it will fill up and eventually overflow. so either take apart the valve and install a filter or replace the valve.
May 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water fills up dishwasher after complete maybe a day or two later
Sound like the hot water sonenoid is stuck in the open position. Locate this solenoid and tap it lightly with a small hammer while the hot water is open. If it does not stop it will beneficial to have this part replaced. I hope this will help.
Jan 17, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
