Question about Dishwashers
Why is the door of the dishwasher not staying open when I push it down to the open position
  • 1314 Answers
SOURCE: Dishwsher door
hes right what can i say
Posted on Jan 27, 2008
SOURCE: Kitchenaid dishwasher door does not stay up in the open position.
On each side of the dishwasher, near the ground, is a nylon cord and pulley apparatus that keeps the door from flopping down when opened. It probably needs some adjustment of the tension on the cord.
Posted on Feb 14, 2009
  • 63 Answers
SOURCE: cd tray is stuck in open position on my HP computer
In Some Cases The Button May Be Stuck In Causeing It To Keep Pushing It Open In Other Cases The Arm May Just Be Stuck To Extending The Tray Out. I Recommend Seeking A Computer Technician If You Do Not Know Anything About Computer Componants
Posted on May 12, 2009
smartr10U
  • 1305 Answers
SOURCE: dishwasher door
You're right a spring has either snapped or come off of it's anchor point. Should be 2 ...one on each side of the door. you can order parts on line at several appliance replacement part suppliers... have your make and model so you'll get the right parts. K
Posted on Jun 10, 2009
SOURCE: Cannot open the dishwasher door. Maytag Quiet Ser...
This model has a problem where the handle must be depressed fully upwards to allow the latch to clear completely without straining the mechanism. The lip on which you pull open the door gives the operator a better handhold to force it open even when the mechanism is not fully depressed. Do this enough times, and the plastic tabs on the handle begin to fatigue and eventually break. The handle becomes lodged but can be forced down to eventually open the washer. By this time, a specific portion of the latch that depresses a micro-switch will most likely be broken, and the washer won't turn off if the door becomes ajar. Remove the torque screws along the inside perimeter of the door and you can spread the face panel open to access the latch unit for replacement.
Posted on Jul 11, 2010
How do I remove oven door
open the oven door all the way and look down at the hinges. there is a little locking clip that you swing into position that locks the hinge from closing. it might be stiff and need some cleaning depending on how old and dirty your oven is. Also you might have to push down on the oven door to make the hinge open fully to get the locking tabs into place. making shore that the locking clips stay in place and hold open the hinge as you lift the oven door slowly towards its closing position and you will see the whole hinge lift up from inside the oven cabinet and the door will just lift out. be careful not to catch your fingers. make sure the looking tabs stay in place during removal as the hinge is very hard to get back into this position again. re fitting is the reversal making sure that you have pushed the base of the door all the way back into the cabinet and push down on the as to open it to release the tabs.
Sep 23, 2016 | Ovens
Door Latch in lock position & will not open?
you need to push on door, or, and move, door side to side and up and down while attempting to move latch to open.
Oct 20, 2014 | Dishwashers
My kitchenaid DW kudc101xwho will not stay on. Runs a few min and shuts off. Is this the control panel or the timer?
May be this is the reasons.
a) May be your door latch is opening due to pressure inside the dishwasher. The door latch opens and the dishwasher will stop. Quite common problem on KITCHENAID. KitchenAid door is a heavier door compared to sister product WHIRLPOOL. If door latch problem then has to change the door lock along with the top latch.
Sep 25, 2014 | KitchenAid Dishwashers
Door lock
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
Mar 30, 2014 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kitchen Aid KUDD03DT top drawer won't stay closed
The lock lever on the unit --- that is shaped like a U --- if you have it ---may be bent a little. You can move it to the correct position - usually down a little --and your door will stay closed
Mar 04, 2014 | KitchenAid 24" Double-Drawer Dishwasher...
My maytag dishwasher will run for a short then stop running, I'll push on the door the machine will run again then will stop again
your door is not staying latched.. imagine if it did stay running and the door came completely open, what a mess that would be. so there are safety switches that help stop the washing if the door opens. not too sure how to fix your exact washer.. but the problem is the door not staying closed. maybe you can jamm the door shut while it is running? its not the best answer, but probably the most free way to fix it
Oct 29, 2013 | Dishwashers
My KitchenAid Dishwasher door won't stay closed. It keeps popping open after a few seconds.
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
Aug 11, 2012 | KitchenAid Dishwashers
Samsung dishwasher door lock stuck in closed position
take small flat head screwdriver and on the door were the latch is push the screwdriver in about an inchpull on the open handle at the same time ps unplug it first.
Jun 22, 2012 | Samsung 24"" Dishwasher
The door just flys open and slams down with no support. Won't stay closed unless pushed in all the way.
I'm no sure why the door is flying open but it the door is falling without any tension, it sounds like 1 or both of the cheezy nylon lines that hold the door springs or their plastic accessories have bit the dust. Look at page 24 of your installation instructions if you have them. Shows what they look like. If you pull the dishwasher out, you will see them in the front on the lower left and right. Our dishwasher is 7 years old and they have broken twice now.
Nov 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Feb 01, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
