Question about Boating
I have a 90 hp johnson saltwater series i believe it stuck in the slow mode what could b the problem
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Does my 1979 johnson outboard charge the battery thru the powerpack?
Some models charged through a Magneto, but see if you can find the 1979 Year Manual. I have a 1979 engine myself in a 15Hp which is a Manual start(no battery) and I have a Sailhorse Johnson 8HP which has an electric port and is Manual start. I believe the 8HP would charge a battery as on a Sailboat the running lights needed power. The 8HP could power the lights directly.
Johnson offered options for electric start in lower HP units and options in charging systems to contain costs. You might get a better answer from someone by listing the HP of your motor. I was the original owner of the 15HP and remember the 9.9HP and others in the same Sales brochure. The Sales brochure may advertise more about the charging systems.
Jul 21, 2014 | Light Outboard Motor Boat Bass Fishing...
Steering shaft stuck and will no move left or right Johnson 90 hp outboard
Try to tun shaft with vice grip or Stilton wrench(bobbyaan spanner)put spanner nearest to end,try not to damage shaft.if shaft will not turn you will probably have to cut cable and knock out from other side
Aug 26, 2013 | Sierra International 18-4310 Marine...
Starter dragging on 2001 Johnson 90 horse outboard
Check batt wires good contact,check brushes in starter have good earth check batt cables have no black death
Jul 31, 2013 | Light Outboard Motor Boat Bass Fishing...
Need to know how to change lower unit on 1971 johnson 25 hp motor
put into nuetral,undo the five bolts around lower unit,take off sideplate halfway down leg casing,loosen the two bolts clamping the gear rods together,then lower unit should slide down[if driveshaft isnt stuck in the crankshaft spline].assembly is reverse,but take care putting water tube back into rubber grommet,and tighten gear rod clamp only after making sure that g/box is in nuetral,when gear lever also in nuetral,or matched together
Jul 01, 2010 | Light Outboard Motor Boat Bass Fishing...
Johnson 1998 175 hp motor seems to be in safe mode
Jul 12, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
93 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
