Question about Luggage & Travel
2015 Ford Edge lift gate opens randomly on its own. It is not a power lift gate.
Whats happening is your accidentally activating the hands free with your feet by standing too close to the rear bumper
when unloading or cleaning the back.
Dec 24, 2016 | 2015 Ford Edge
Will 51 cubic foot of foam insulation, cover 400 square feet of a wall?
That depends upon how thick the foam insulation is. That is the only way to compute from cubic feet to square feet.
To simplify, assume the foam is 1 foot wide by 1 foot thick by 51 feet long. That is 51 cubic feet of foam. If you slice the block lengthwise at 1 inch intervals, you get 12 slices, each 1 foot wide by 51 feet long by 1 inch thick. This is 51 square feet of coverage at 1 inch. You would be able to cover 51x12, or 612 square feet.
Increase the thickness of the slice to 1-1/2 inches, you only get 8 slices, or coverage for 408 square feet.
Any thicker than that, and you won't get enough coverage for 400 square feet.
Aug 05, 2016 | Cars & Trucks
Can someone tell me what the square footage is in a board 2 inches thick 8 inches wide and 8 foot long please
if you are staining the edges and both sides it will work out as follows
Each flat side is roughly 5.28 square feet or 10.5 square feet total per board.
The edges add rougly another 2.4 square feet so rough answer would be 13 square feet per board.
Jul 10, 2016 | Office Equipment & Supplies
How many linear ft are in 779.5 ft?
Are you talking "Board Feet"? If so, to calculate board feet take the length of the wood multiplied by the width, and multiply by the thickness, then divide that by 144. For example: To calculate how many board feet are in a 1x6x8 you would multiply 1 x 6 x 96 = 576, now divide that by 144: 576 / 144 = 4.
Feb 23, 2015 | Vehicle Parts & Accessories
In what direction should the plastic, 8-blade, aftermarket replacement for the metallic OEM fan turn when installed?
Find me helpful, the feathered edge is always the trailing edge. Find my other posts to your same question helpful, The B side, thick edge goes towards the engine on your belt-driven ford ranger fan. This is not rocket science. in-direction-plastic-8-blade-u40lsvyytnuesyuv3fbafhtd-1-0.gifa picture just 4u.
Jan 01, 2015 | 1987 Ford Ranger
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Sep 07, 2009 | Televison & Video
USB port dislodged on 1TB Seagate, how do I open the case?
I did open a Seagate FreeAgent Pro 1TB !
The thing was awful, the case is just a nightmare to crack. The base is easy, you have the screws under the tiny rubber feet. The metal over the electric parts is easy to take apart, you just unglue and carefully open. You unscrew then the four flat-headed screws the hold in place the electrics, and the three big ones that hold together the base and the upper part.
Here comes the nasty part.
You unplug all connectors, but the upper case is VERY (I mean VERY) well tightened. It's held in place in 4 points, and the plastic made my fingers bleed. I can surely say it's a very well made case, strong as military, but impossible to open without destroying.
In the upper part the plastic holding points are quite close to the lower edge, but the two lower ones are somewhat 2,5 or 3 inches away from the edge, and this is where you'll get stuck. I couldn't just pry them open, so in the end, even though the unit is safe and sound, the lid (the part with the Seagate logo) was torn an bent.
My problem was at the electrical part, so I don't care much for the case, but I feel bad for having to literally destroy such a good-looking external enclosure.
Hope this is helpful to all of you in trouble with this issue !
Dec 16, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Luggage & Travel Logo
215 people viewed this question
Top Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
Bobby Lewis
Bobby Lewis
Are you a Luggage and Travel Expert? Answer questions, earn points and help others
