My Diesel Audio NS-994 will not play a dvd,cd,or an mp3 either it just says ERR DISC!
  • 1689 Answers
SOURCE: DVD player not reading dvd's
Check the link below to see how to clean the laser on a DVD player. If cleaning does no work, then the player will need servicing.
Jerry G.
Posted on May 14, 2008
SOURCE: Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Posted on Aug 12, 2008
  • 2992 Answers
SOURCE: Sony CD/DVD Player DVP-NS50P not playing my avi files DVD+RW
You need to convert avi files to dvd format before burning, otherwise the player won't recognize them. Google "avi to dvd" and you'll find a number of free or pay programs that will do the conversion for you.
Posted on Nov 19, 2008
  • 45 Answers
SOURCE: Disc error when reading dvd
If cleaning of the lens did not help then it is possible that the laser beam torch needs a replacement. Different formats need different strengths of the beam and the torch would need to be replaced.
Posted on Jan 15, 2009
SOURCE: Polaroid PDM-0711 DVD player won't play DVD's but still plays CD's
I've got the same problem, I turn my player on it's side until it reads the disc. more of a band-aid solution.
Posted on Feb 15, 2009
My Insignia NS-WBRDVD2 will not play the HD DVD-s...why
This Blu-ray player will not read HD (high density) DVDs. The format is not the same as a blu-ray. You would need an HD DVD player. (if you can find one - they are rare.) If you are having trouble reading specific Blu-ray discs, you should check if there is a firmware update for the unit on the Insignia site. Start at and look for downloads for the NS-WBRDVD2.
The NS-WBRDVD2 reads Blu-rays, DVD-ROM, DVD-RW, DVD+RW, DVD-R, DVD+R, CD-R, CDDA (audio CDs), CD-RW, MP3, MPEG4, JPEG. Discs burned on DVD recorders/computers must be finalized to be played on the unit.
The manual for the unit is available from Insignia here: .
I hope this helps.
Nov 02, 2011 | Televison & Video
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Mar 21, 2011 | Durabrand DVD-1002 DVD Player
It keeps saying unknown disc,every time i put a disc in there every disc that i put in the will not play keeps saying Unknown-disc...including an audio-disc.
hi, try first to insert a clean up CD, and test your Cd or Dvd player with an original CD or Dvd, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
Apr 12, 2009 | Insignia NS-VDVD1
Don't play any disc,every time I try no disc or err disc massage will apear
I have owned insignia dvd players in the past. When I got the "no disc" message I simply cleaned the inside of the machine. To do this you can get an old CD and tape a soft paper towel to a fragment of the readable side. Then insert the cleaning CD into the machine (do no use liquids) and let it run a few times. I found that after I did this a few times it seemed to clean the lens and would read discs again..
Mar 21, 2009 | Insignia NS-H2002 Theater System
DVD player repairing
Double-check your DVD player's user manual/spec sheet to see if it plays Mp3 format files at all. Find out, specifically what kind it can read.
If your Mp3 disc is a DATA CD instead of an AUDIO CD, then nothing besides a computer is going to play it.
Sep 05, 2008 | Philips Magnavox DVD/VCR Dual Player
Insignia NS B2110 boombox CD not playing
Try an audio CD which has been purchased. I think you have MP3's on your cd and your boombox maybe does not support MP3
Mar 07, 2008 | Insignia Sport lDM9700-2 Personal CD...
Err disc
The laser eye is tired(out of alignment) from playing alot of burned disc. Have some one who know re-align it. Goodluck.
Mar 07, 2008 | Dual XDVD8180 Car Video Player
Mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Oct 02, 2007 | Philips DVD 622 DVD Player
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
