Question about Diesel Audio Car Audio & Video
How do I set the clock ony Diesel Audio NS -994 head unit?
2 Suggested Answers
  • 50 Answers
SOURCE: How do I change/set the clock setting on my car head unit? (actually a CDX-GT150)
press and hold the volume control and it should give you options on changing the clock.
Posted on May 26, 2009
UnABLE to set the clock on my car audio system.
Here is a link to how to set the clock for your head unit.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/DEH-P7400HD_OwnersManual112811.pdf
Mar 19, 2014 | Pioneer Deh-p7400hd In-dash Car Stereo...
Connections for diesel audio roof monitor
I don't know about the audio roof monitor if you have some info kindly share it with us. i have one link about roof leaks repairing.
Liquid EPDM Rubber
Jan 09, 2014 | Diesel Audio NS-975 13.5 in. Roof Monitor
I just got a new Diesel Audio NS-9915, I dont have manuel so I can not set clock or adjust sound I need help! Please
go down to auto zone or advanced auto napa ect!!!
order a haynes repair manuel
they cover every thing from (codes) to electrical
motor / transmission / rear ends / drive train
i find its very informational
hope this helps you
good luck
bob
May 08, 2011 | Diesel Audio Car Audio & Video
I have a Vizio 210 soundbar and the remote control is junk! I want the code the woeks on my Comcast universal remote control.
After much research, here is a step-by-step for getting your Vizio Soundbar to work with the Comcast remote using EFC codes (mine is the newer charcoal grey one, works great!)
Aux - Setup (2 blinks) - 11144 (2 blinks)
Aux - Setup (2 blinks) - 994 - Setup - 00169 - Vol Up - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00168 - Vol Down - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00037 - Mute - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00165 - Power - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00164 - Input - Should get 2 blinks
These are optional, I didn't use them:
Aux - Setup (2 blinks) - 994 - Setup - 00036 - <button to use for TVOL> - Should get 2 blinks
Aux - Setup (2 blinks) - 994 - Setup - 00101 - <button to use for TSHD> - Should get 2 blinks
Then set the volume control on the remote and other settings according to the Remote's manual.
ENJOY!! Hope this helps someone...
Nov 14, 2010 | Vizio High Definition Sound Bar
I have a 250 watt / 4 ohm subwoofer i have a diesel 700w amp / 2 channel / hpf or lpf with bass boost. i dont have speaker wires and want to utilize my to speakers in the back of my 2008 mustang to...
if you are trying to use it with the stock headunit you would need to buy a line output converter to use your amp and sub. after you buy the converter you will then need to splice into one of your rear speaker wires so you can run the rca's to the amp and continue with normal install
Aug 10, 2010 | Diesel Audio NS-700 Car Audio Amplifier
HOW DO YOU SET THE CLOCK
turn off the head unit with the car on. Press and hold mode until you get to a menu screen.
There you will find options to set clock and other functions of the head unit.
Dec 15, 2009 | JVC KD-R200 Car CD/ MP3 Player
May 26, 2009 | Sony CDX-GT110 CD Player
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
NS- 1600 amp
You need to use a multimeter to confirm that you have a good ground and sufficient voltage on the B+ and remote wires. I'll assume that you've checked the on-board fuses (if it has them).
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v and the amp does nothing, the amp probably has a blown power supply.
May 03, 2008 | Diesel Audio NS-1600 Car Audio Amplifier
Diesel audio NS-600
it can be done providing it isn't driven too hard.
May 19, 2007 | Diesel Audio NS-600 Car Audio Amplifier
Car Audio & Video Logo
41 people viewed this question
Top Diesel Audio Car Audio & Video Experts
armando martinez
Level 1 Expert
Tom Chichester
Are you a Diesel Audio Car Audio and Video Expert? Answer questions, earn points and help others
