Error code 91.03 on a trane tzone 950ac52za - Heating & Cooling
  • Heating & Co... Master
  • 1,922 Answers
Turn breaker off to air handler for 10 seconds, then back on. Give time to initialize and see if error clears. If not go into technician access to diagnostics. I believe in there you will find summary table. SUMMARY TABLE is what you need. Whatever is "offline" is the problem. Delete that item and go from there.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 21, 2016
Trane XL850 error code 177.40 what does it mean?
It's an 'emergency shut down' and can only be cleared by cycling power. Looks like from the description that the heat pump is trying extra hard to keep up. You MIGHT could prevent this by going to AUX heat which would turn on your heat strips. I think.
There's more to the error code.
Here's the PDF. It's on page 22.
http://www.chapmanair.com/4TTV00.pdf
Jan 02, 2018 | Heating & Cooling
I have a Trane heat pump that shows error 79
79 i believe is a low pressure error code. This means you are low on refrigerant
Nov 12, 2016 | Heating & Cooling
My Trane AC thermostat (900 TOuchsreen) has an error code 126
Error code126 is equipment does not match value at startup. Usually a power surge or brown out can cause this problem. Turn power off to inside and outside unit, wait 5 minutes. Retry system.
Jul 15, 2016 | Heating & Cooling
5 u code is on how to fix it
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Here are error codes found on many York, Trane, Luxaire, Lennox, Carrier, ... If younotice 5 red colored flashes on your York Furnace, it signifies that your
Oct 03, 2015 | Cars & Trucks
Trane xv95 converted to propane is on system lockout
There is either a problem with the ignitor or the flame sensor.
Nov 18, 2013 | Honeywell Electronic Programmable...
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
Oct 31, 2013 | American Standard Trane Ge Gas Furnace...
Rocada xphone using tmobile cannot receive tzones or video/audio
good news i can solve this problem. this is what you do. ready? first call tmobile (611) when you reach a customer rep ask for (data support). from there tell them what kind of phone you have and tell them you need them to send tmobile settings to your phone they may do it or they may redirect you either way your on your way. then once they do that download the settings on your xphone when that is done go to your tzone profile on your xphone and change (http) to (wap) and then you should be able to access tzone. this work for me and i have tzone on my rocada gold xphone. now they may tell you they have multipal settings so if the first dont work tell them to send another one. there you have tzone on aw rocada xphone.
Jan 15, 2009 | Cell Phones
Trane Furnace xv-80
check the pressue switch and make sure that nothing is in the fan that would cause it to not draw. I have seen water inside of them at times due to the high efficentcy of the units. let me know if this does not solve it please.
Dec 28, 2008 | Heating & Cooling
Heating & Cooling Logo
634 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
