Question about Bush Televison & Video
I have a new 49 inch bush smart tv. Every couple minutes a white line flashes up and it makes a interference noise . Anyone else had this problem ?
  • 7 Answers
SOURCE: 32 inch dell lcd3201c tv...
The cost to fix this is more than buying a new TV. get rid of it.
Posted on Dec 05, 2008
  • 11361 Answers
SOURCE: My 32 inch Vizio TV will turn on but within about
The high pitch sound may be coming from the power supply module or from the backlight inverter boards.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps.
Posted on Oct 09, 2010
  • 616 Answers
SOURCE: i've had a rca model
Sounds like the power supply has filtering issues, in other words bad capacitors. its best to have a tv shop take a look at it. they shouldn't charge you. good luck
Posted on Nov 06, 2010
SOURCE: vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Posted on Jan 25, 2011
  • 373 Answers
SOURCE: Dell 42 inch TV. Problem: Horizontal lines and
You need to reseat all the connectors inside the TV. Just unplug and re-plug back all the connectors.
Posted on Jun 02, 2011
Netflix wont play anything on my bush smart tv 49 inch. Netflix have said its a problem with the device. I have already tried rebooting the tv with first time installation
not sure if this will help you out,,,
Here's how to fix many Netflix streaming problems. Restart your iPhone, Smart TV, Game Console or whatever device you are using to stream Netflix. Restart your Router. Unplug your wireless router from power for 60 seconds then plug it back in.15 Oct 2015
14 Common Netflix Problems & Fixes - Gotta Be Mobile
or go to this link... Netflix wont play Google Search
Oct 24, 2017 | Smart Computers & Internet
Samsung TV LN32A550P3F problems. About 4 minute after turning on screen displays some picture with vertical lines & a lot of louder white noise over the normal sound.
Please check sound on main power board. Could be a failing component that is heating and not functioning normally that is causing interference and thus the vertical lines.
Nov 18, 2016 | Samsung Televison & Video
Hi I have a bush 3d smart TV 42inch bought only a couple of months a go, I was watching TV and it turnt off now it just keeps turning on and off the controller won't work, it won't change to any channel,...
Return to manufacturer or shop where you bought it and get a new set. The controller may need factory resetting but you don't have to put up with this and it is still under warranty.
Nov 28, 2014 | Televison & Video
Toshiba lcd tv 32" making noise by speaker
test this steps and fix it. God bless you
Line noise is feeding in from the AC line. Use an AC liner filter to block the line noise. RF (radio frequency) interference is being picked up by the power line or wiring. Remove sources of RF interference, such as fluorescent lighting or wireless devices not designed to work with audio/video equipment. Wires between the components are on top of one of the components; the transformers are causing RF interference. Be sure that wiring goes behind the components rather than on top or between components. If there is an equalizer in use, there could be a ground loop. Ground loops can be resolved by installing GLI's (ground loop isolators) on the cables connecting to the equalizer.
Jul 25, 2013 | Toshiba 32AV502U 31.5 in. LCD HDTV
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
Buzing noise from power unit
What kind of system is it?
What "power thing" inside what?
It's a good chance its a ground loop issue.  Make sure the power cords aren't wrapped around each other or touching the speakers or running parallel with the speaker wires for more than a couple inches (interference transmitted into the speaker lines audible through speakers).
Aug 04, 2009 | Sony DAV-SA30 System
Nov 07, 2008 | Dell W3201C 32 in. LCD Television
Televison & Video Logo
20 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
