Question about Miscellaneous
Return package from Dec 1, 2016 - Miscellaneous
How do I return merchandise
  1. Each business will likely have both its return policy and its return procedure on its website. That might be something like as follows.
  2. First, the customer must call the technical support office and speak with a technician. ...
  3. Secondly, the customer must write the RMA number on the outside of the box that the product is being shipped in. ...
  4. Finally, the customer mails the product.
Return Mechandise Authorization number.
Below link is to the support page to return an Amazon gift.
Amazon com Help Return Gift
"If you don't open the package, you can write "Return to Sender-Refused"on it. Your carrier should pick it up the next day or you could drop it off at the stamp window of your local post office. Once you open the package however that constitutes "receiving the package" so you must pay to return it if you have opened it". Quoted from Quora
Aug 10, 2017 | Computers & Internet
I have almost the returns to send to Amazon can I group them bundle them in as less packages
-You mean you want to return couple packages and pack in 1 package to return to Amazon ?
-I think you can but make sure all the items you return must have
authorization before you return.
Good luck
May 16, 2017 | Amazon Computers & Internet
I would ask the company you placed the order with, Logan. They would have a far better idea about the holiday crunch with all the packages being shipped right now.
Dec 21, 2016 | Computers & Internet
Amazon order was undeliverable. Where is item? How to get it delivered? Can I cancel it and later reorder to new address?
About Undeliverable Packages
Occasionally packages are returned to us as undeliverable. When the carrier returns an undeliverable package to us, you will be issued a full refund (including shipping charges).
Orders that are returned to us as undeliverable are not able to be re-shipped. If you would still like to purchase items that were undeliverable, you are welcome to place a new order on our website.
If it has been four weeks from the estimated delivery date and you haven't received confirmation of the return or refund, please contact us.
Jan 14, 2016 | Brother CS6000i Computerized Sewing...
I want to cancel my Somnapure trial, It is under 18 days
To receive your refund, your return must be received at our shipping facility within 30 days of purchase. Be sure to clearly write the return merchandise authorization (RMA) number on the outside of the package. Our shipping department is NOT allowed to accept any packages without an RMA number. You pay for return shipping. Please send your package to the appropriate facility:
  • In the United States: Peak Life - BP 3, 105 Commerce Dr, Aston, PA 19014.
  • In Canada: Peak Life Returns, P.O. Box 1051, Fort Erie, ON L2A 6C7.
  • In Australia: Peak Life, PO Box 535, Braeside VIC 3195.
  • In the United Kingdom: Peak Life, PO Box 1417, Bedfordshire MK41 0QB.
Peak Life Refund and Return Policy
Sep 29, 2014 | Computers & Internet
!!! WARNING: The switch is not usable !!! 3560-24PS
There is a possibility of IOSĀ® corruption, so better check on that before using warranty, RMA or dumpster/recycling
Error Message SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = [chars] / code = [dec] ([chars]) / bytes transferred = [dec].
Explanation This message means that the VLAN manager received an unexpected error return from an IOS file system (IFS) call while reading the VLAN database. The first [chars] is the IFS operation that failed. The first [dec] is the error code, the second [chars] is the textual interpretation of the error code, and the second [dec] is the number of bytes transferred.
Recommended Action Copy the error message exactly as it appears on the console or in the system log, call your Cisco technical support representative, and provide the representative with the gathered information.
Mar 21, 2013 | Cisco Catalyst 3560-24PS Switch
How do I convert to binary with the Casio fx-CG10?
Press the Menu key. Press 1 to select the Run/Mat icon. In main screen, press SHIFT MENU to enter (SetUp). On the 2nd line Mode: Select DEC(imal) numeration. (Do not select the usual COMP mode). Press EXIT to return to the main calculator screen. Enter the base-N identifier (d, h,b, or o) followed by the number expressed with the correct digits. Press EXIT to return to the screen with the tabs d tilda o, LOGIC, DISPLAY. Press F3 for DISPLAY , use F1 (>Dec), or F2>Hex etc. to display the number in the base you want.
Feb 23, 2012 | Casio Office Equipment & Supplies
Miscellaneous Logo
18 people viewed this question
Top Miscellaneous Experts
Randy Hughes
Randy Hughes
Joey Gammon
Doug Davis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
