Question about Polti Vacuums
My polti vaporetto go machine has stopped working, I think I may have overfilled the water tank now no lights, no steam no nothing!!
SOURCE: Polti Vaporetto
Dear Terena
Had the same problem with a polti vaporetto 1500 ( vtt 1500 ) after butchering the big valve on the top I realised that the problem was that there was a blockage in the black pipe that comes from the machine to the trigger, the pipe that carries the steam in other words, so I got a piece of wire ( brake cable form a bike shop ) long enough to go at least half way down the pipe and then I pushed the wire down the hole at the trigger end and then from the other end that joins to the polti and hey presto the blockage was gone and the machine works fine again. If you use the machine again after you have cleared the blockage from the pipe you should be able to remove the valve from the top remeber that the water is now steam so it is very hot and will burn you so be carefull when opening the valve when hot I think that you will have to open it when it is warm not hot as what has happened is that scale has got in the threads of the valve and sealed it, so if you get it undone ( try pushing it down hard as you turn it Whilst it is warm only not hot ) then get some kettle descaler and put some in a bowl of hot water and put the valve threaded end in the descaler for 10 minutes to get rid of the scale and in the mean time put some descaler around the threads on the polti where the valve goes this will allow the valve to screw back on easily and you will be back to normal use again remember to keep the valve screw threads free of scale in the future I have only just reallised this so dont feel alone.
Pete
Posted on Dec 04, 2007
  • 17 Answers
SOURCE: NO STEAM EVEN THO THE DIAL GOES RIGHT UP TO THE RED
Hi i've had the same problem Put a phial of Kal stop into 1000 or 1500ml of water into the tank, let it heat up and it should break down the limescale of the solenoid. It's worked for me. Have a good evening;-)
Posted on Mar 11, 2008
  • 17 Answers
SOURCE: Polti Vaporetto 2400: Water out light comes on when tank is full
Hi you need to put 5ml of Kal Stop fo Polti machines into 1000/1500ml of water into the tank, The stronger solution is better (1000ml) Let it heat up and this should break down the limescale on the solenoid. I tried this today and it has worked saving ££££'s in repair by Polti.
Ranglo
  • 1194 Answers
SOURCE: lost instructions for vaporetto polti 2400
Download instruction manual for Vaporetto 2400
Good Luck
Rating the solution is highly appreciated
Posted on May 31, 2010
SOURCE: How do I undo the torx screws that hold the Polti
Hi you need the torque driver no 20 the problem I had was the 2 middle screws luckily a friend of mine had a set of torque allen keys they were long enough to remove them hope this helps if you llived in the North East I would have let you borrrow them
Regards Tony
Posted on Aug 10, 2010
No steam from my almost new Polti 2600
It sounds like the solenoid isn,t activating when you pull the trigger which then lets the steam out. It either wants stipping and checking or returning to where it came.
Apr 19, 2009 | Polti Vaporetto 2000R Vacuum
Starting a polti vaporetto steamer
Put a couple of lts. of water in the tank, replace lid, assemble hose with tool you require. Plug in switch on, wait for needle to climb into yellow then pull trigger for steam
Jan 23, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
Vaporetto 2400 no access to water tank
The threads have probably stuck together with limescale. Push down with reasonable force while turning the cap, like you would if you were trying to get in one of the childproof bottles. This should crack the limecale and allow you to take it off. Then descale the threads on the top and machine using kalstop or whatever you use.
Jan 16, 2009 | Polti Vaporetto 2400 Canister Steam Vacuum
POLTI VAPORETTO PROBLEMS
Hi, It is the solenoid that is sticking, It there fore needs opening up, the solenoid valve stripping and cleaning, or replace at a cost of about £12 then putting back together. they don,t like being left and not used. It is possable if you keep clicking for it to start working again.
Dec 09, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
Dec 10, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Nov 04, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Polti Vaporetto
Dear Terena
Pete
Sep 26, 2007 | Polti Vaporetto 2400 Canister Steam Vacuum
Vacuums Logo
98 people viewed this question
Top Polti Vacuums Experts
Billy Detlefsen
Are you a Polti Vacuum Expert? Answer questions, earn points and help others
