Question about Garden
Magneto wireing on a briggs&straton 6.75 horse power dr power trimmer?
Beleave it is the ground wire needs to complete the cir ?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Garden Master
  • 969 Answers
George, there should only be one wire usually black. comes from the coil to the kill switch.
Posted on Dec 19, 2016
How to make a stop switch for briggs model 350447-1206?
all you need to do is ground the wire from the magneto. install a wire from the block to a simple on off switch and another wire from the magneto to the switch
Aug 29, 2014 | Briggs & Stratton Garden
I need a wiring diagram for a 12.5 horse briggs & straton i/c engine
its a small system there is a coil under the flywheel and magnets on the inside of the flywheel on the coil there is two wires one for headlights puts out ac the other has a diode to putout dc the recharges the battery the output is only about 4-7 amps remove the top cover and look to see if a mouse eat a wire if not check the diode a diode is a electronic valve if no power on the side with the connector check for ac power on the other side of the diode it will look like a bubble in the wire you can buy a diode at radio shack
May 28, 2012 | Garden
I HAVE NO SPARK ON MY BRIGGS AND STRATON MOTOR
Try this locate your coil / magneto and disconnect the kill "shut off wire " and try to start if it starts your switch may be bad or wire broken..if still no spark using a rubber handled pliers ...Pull your plug wire and place a screwdriver or similar metal piece and in the plug wire now bring the screw driver close to the engine block or Frame if spark it is your plug..if not your coil needs replaced...not a hard job just use a business card to set clearance on your coil..good luck
Jan 18, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
How to fix an off and on switch on a briggs and straton model series, 19e400 5000 watt, on and off switch located on top of the motor. is there a wire thats supposed to hook onto the switch somehow.
Kill switch should have a wire connected to the tab on the spark coil under fan cover. The switch is a means of shorting kill wire to ground. On some generators, there will be another method of shutting down the engine. Usually on/off switch will be more visable on the control panel. Most likely the switch on fan cover was not connected to prevent confusion.
Sep 14, 2011 | Briggs & Stratton Briggs and Stratton...
No spark 10 hp briggs+straton model 19E412-010701, ON/Off Switch broke replaced that, but get no spark
Remove the kill wire from the the back of the ignition module and test to see if you then have spark. If you have spark you would have a bad ground but if you still do not have spark then you may have a bad ignition module.
Jul 26, 2011 | Briggs & Stratton Power Products 5,550...
Have a 9 horse troy built 33in walk behind mower,I want to replace the engine with a another briggs a 15 horse, but it has some extra wires to the carburater bowl and I wnat to make sure where they go and...
The wire to the carb bowl is a fuel shut-off solenoid. Needs battery voltage applied while the engine is starting/running. Your ignition switch will need a 'load' connection (battery voltage when 'ON' or 'START', off otherwise.
If your ignition switch is not suitable, you will have to rig something.
Jun 23, 2010 | Garden
Wiring on an old 5hp Briggs and Stratton engine
The "heavy wire" connects to the spark plug. It should have a plug connector attached. There are 2 small wires. One of them grounds to the engine block (probably through one of the screws that holds the magneto in place). The other wire goes to the condensor/capacitor.
Nov 30, 2009 | Air Tools & Compressors
Craftsman with a 19.5 hp briggs & straton engine. Worked fine was not used for 3 weeks then would not start, lot's of fuel however no spark at the plug. Any idea what I should look for before taking in...
disconnect the ground wire from the coil magneto and recheck your spark. if no spark coil may be bad. if you have spark the problem is somewhere in your wiring harness
Oct 12, 2009 | Garden
Not firing
After you check the key and key way,Check the coil wire to see if it has any breaks in it,If no breaks are present,Replace the coil.
Jun 02, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
