Clorox don't not mix with Tide - Washing Machines
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    www.stain-removal-101.com/washing-machine-stains.html
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    https://www.clorox.com/...laundry/removing-yello...
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb
    ths.gardenweb.com > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
Musty smell
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very, very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap ****/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called
"TIDE WASHING MACHINE CLEANER" which is very effective.
Service manual and more can be found at this BLOG of mine
Jun 12, 2012 | LG Washing Machines
Where was the salt water goes after the low tide?
Is this for the summer school class that you're taking because you flunked science during the regular school year? It goes to the part of the earth that is experiencing high tide. There's always high tide somewhere... it's generated by the gravitational force from the moon. Shhhhh... don't tell Bill O'Reilly from Fox News, he thinks it's God talking to us.
Aug 15, 2011 | Computers & Internet
The door gasket on my LG Tromm WM2377CS washer always has water trapped in it. The three tiny drain holes have been getting more and more clogged with "gunk". How to get the drain holes cleaned...
I use nylon cable (zip) ties to clean them. (Not sharp, so no danger of poking holes in the gasket) You may want to run a washer cleaner through the machine occasionally, such as Affresh or Washer Magic, or one made by Tide or Clorox.
Jul 23, 2011 | LG WM-2277HW Front Load Washer
Can you please tell me if you have a product suitable for cleaning drapes. fabric lounges and carpet?
have you tried fabreeze or tide. Clorox may work also. Check their websites.
Jan 05, 2011 | Clothing Accessories
I want to play the steel tide without CD inseeted in the CDROM
Hello timpugrt
You can download the latest no-cd patch from here:
http://m0002.gamecopyworld.com/games/pc_operation_steel_tide.shtml
Make sure you back-up the original .exe file before replacing it.
Hope this helps. If you require further help, please donĀ“t hesitate to ask.
ajblaj
Sep 10, 2010 | Infogrames Steel Tide for Windows
ALGEA AND WATER HAVE BUILT UP INSIDE AIR CONDITIONER - HOW TO GET OF IT
Spray everything down with a clorox and water solution in a spray bottle. Mix 1 part clorox to 10 parts water. Then place a few ounces os clorox in the water in the drain pan. Many window a/c units are leaving water in the pan and using it to help cool the condenser coil now. Not really a great idea in my opinion.
heatman101
Aug 20, 2010 | Haier hwr10xc6 Air Conditioner
How can I remove mold in the cylindrical rotating blower in my ductless Fujitsu AOU18RD
Mix up a solution of clorox and water, like 1 part clorox to 10 parts water...then place it in a spray bottle and spray down the blower woth the solution...then you will need to carefully take a paper towel or rag and wrap it around something like popsicle stiack and carefully wipe the mold out of there...it is tedious and time consuming, but it will work and can be done...
heatman101
Aug 07, 2010 | Fujitsu 24C1 Air Conditioner
Clothes come out of dryer with a fish like smell, the lint screen is cleanit is a kenmore 90 series gas dryer and the washing machine is an kenmore elite top loader about 8 years old the laundry detergent...
Chances are, the odor is from the washing machine.
Do the clothes smell when you take them out of the washer or after they have been in the dryer?
Tide makes a washing machine product that can help deodorize a washer, but using white vinegar with a hot wash cycle (empty) will also help. I think Home Depot or other home improvement stores may carry the Tide product. Maybe even your local grocer.
Also check the dryer for any odd odors. Sometimes scented dryer sheets put into the dryer with it empty can help deodorize it, or you can manually wipe the inside of the dryer with a product like Clorox Wipes. Check the dryer venting for any obstructions or restricted air flow just to be sure.
If the problem persists and it it still smells, it's possible (not too likely) you could have a pest issue, depending on your location and time of year.
Jan 28, 2010 | Dryers
Also can't get whites clean in out front load washer
try using a bit of automatic dish soap in with the detergent and bleach .Ifound that to do wonders
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
