Question about Sansui Televison & Video
Need an user manual for my SANSUI 5.2 CHANNEL COMPONENT SYSTEM HT4007 EX please
Where to find the owners manual for the Sansui QRX 7500A?
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Dec 19, 2015 | Audio Players & Recorders
How to manually set a channel on different position in sansui tv?
Download the user mnaual to your TV. It will have all details. You haven't given andy detail of your Sansui TV here. Want its model number to give you more details by this window.
Jun 03, 2012 | Sansui Televison & Video
Sansui SV-2110K, Channel lock
Click here and try to download the user manual to your Sansui TV, and refer it how to make a factory reset to your tV. If it do not help you, the main system memory IC might be faulty, and should be replaced.
May 14, 2012 | Sansui Televison & Video
How to program a Sansui model #HD LCD 2200 for digital tv. I no longer have cable and have misplaced the user's manual.
HI,
this is the manual and you need the cable tp program it...you can get it easily at a affordable cost
http://tv.manualsonline.com/ex/thread/view/idThread/2442932
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | Sansui HDLCD-2200 22 in. LCD TV
Want user manual
here is a link to your manual
http://support.rca.com/doc/Device_Documents/manuals/RCR311B_manual.pdf
the codes for a sansui tv are:
Code For Model RCR311B
Code 1191 for Sansui TV Code 1247 for Sansui TV
instructions:
1. Manually turn on the component you want the remote to control (TV, VCR, DVD, satellite receiver or cable box).
2.Press and hold the TV key. The illuminated ON•OFF key turns on andremains on. If you release the component key at any time during theDirect Code Entry procedure, the illuminated ON•OFF key blinks fourtimes, and the process is exited.
3. While holding down the TV key,use the number keys (0-9) on the keypad to enter the first code above.While you are pressing the numbers, the illuminated ON•OFF key turnsoff.
4. After the fourth number is entered, the illuminated ON•OFFkey turns on. At this time, release the TV key. If the illuminatedON•OFF key turns off, you have entered a valid code and have followedthe correct procedure for Direct Code Entry. If you enter a code numberthat is not in the Code Lists or you do not follow all of the steps forDirect Code Entry, the illuminated ON•OFF key blinks four times whenthe TV key is released. This is an indication that a programming errorhas occurred. In that case, repeat the Direct Code Entry process fromstep 2 and try the next code listed.
5. To confirm that thecomponent key is programmed with the correct code for maximumfunctionality, test the component. Attempt to control a variety of thecomponent’s functions with the remote. If some of the features of yourcomponents do not work, try programming the remote with a differentcode in the list until you find the code that allows the remote tocontrol the majority of your component’s functions. Different codes canprovide different levels of functionality.
7. Remember to write the code down for future reference
Sep 05, 2008 | Sansui Televison & Video
Sansui TVM1316
try channel 65 and connect via antenna cable.
Jan 04, 2007 | Sansui TVM1316 13" TV
Televison & Video Logo
23 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
