Question about Hotpoint Dishwashers
Hotpoint DWF31 dishwasher went bang mid cycle and mild smell of burning plastic. Still powers on, lights on correct setting but stuck at 77 mins with nothing happening. Water still inside. Any ideas
  • 1,920 Answers
Sounds like you have burnt something. May have shorted out. Shut it down and pull the plug or could maybe cause a fire. Get a professional to look at it.
Posted on Jan 21, 2017
  • 641 Answers
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
Posted on Sep 15, 2007
SOURCE: Hotpoint DC28 Dishwasher Problem
u will more than likely find its the element... and i would not charge that for to come out.. ive one here im doing.. u can get the part for 40 quid on the net.. im charging to fix this one 90 in total.
let me know what happenes
Posted on Oct 17, 2007
  • 2920 Answers
SOURCE: Dishwasher burning smell now not working
it sounds like the motor may have burnt out
Posted on Jan 13, 2009
  • 297 Answers
SOURCE: Kenmore dishwasher model 665 stalls in mid cycle
you have a clog somewhere.
Posted on Jul 15, 2009
SOURCE: hotpoint aquarius fdw20 fault lights
yeah i had same problem turns out its a blocked outlet hose
Posted on Nov 22, 2009
Machine went bang mid cycle and tripped electrics. If power is sent to the machine it immediately goes bang and emits a burning smell. What is wrong with my machine?
One possibility is that water leaked into the wiring and shorted it. There may be an access panel in front that you can remove to look for signs of leakage.
Apr 25, 2016 | Candy 24 in. CD950 Free-standing...
My Indesit IDL40 dishwasher, loud bang with slight burning smell but still working?
Any burning smell is not good. Indicates that something in there is too hot and perhaps melting something. Could even catch fire......
Could very well be that whatever is responsible for the noise can be causing the problemo.
Sep 25, 2015 | Indesit Dishwashers
Dishwasher was fine till i put it on a full cycle then it went bang twice ..what as gone ?
If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/control electronic. Use the VOM
Apr 05, 2013 | Dishwashers
Kenmore underwater dishwasher 665 series stopped running mid cycle - all lights went out and will not start again. No lights will go on.
see the causes and fix it:God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Jul 21, 2012 | Dishwashers
Hi my dishwasher is only washing sporadically and is emitting a really bad burning rubber smell - what could be causing this
The drain solenoid fails on some models of dishwasher (especially Hotpoint) and produces
a stuck drain valve and a smell of burning plastic. You can look beneath the dishwasher
and with the breaker off to the units and
see if the pie shaped control lever moves freely. It is attached
to a shiny metal shaft. This is part of the solenoid. It should move freely.
If not, then it has failed and will leave the contol valve stuck in one position.
Secure power and remove the C shaped clip, and the two
phillips head screws. The solenoid assembly should slide towards you and the
pie shaped plastic piece should slide off. It costs about 40 dollars usually.
You will need the model and serial number off the inside of the door to get the new
one. Check online for a better price. Hope this helps.
Mar 10, 2011 | Dishwashers
Hotpoint washer/dryer aqaurius stopd mid cycle with message F-01
f01 is a motor short circuit. you will probably need a new one and maybe the circuit board that powers it if all the lights went out unless the fuse is gone.
Jan 28, 2009 | Hotpoint Aquarius WD63 Front Load...
Jan 13, 2009 | Dishwashers
Hotpoint aquarius fdw20 fault lights
take base plate off and check for debris in the wash pump
Jan 11, 2009 | Dishwashers
Oct 15, 2007 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
49 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
