Question about Humidifiers
Essick11 600 humidifier does not turn on - Humidifiers
How do I fix my blower problem on my humidifier?
Free Sears Humidifier User Manuals ' ManualsOnline.com
homeappliance.manualsonline.com > ... > Household Appliance Sears
Products 1 - 11 of 11 - Sears Humidifier 758.144120. Sears Kenmore Evaporative Console Humidifier Owner's Manual. Pages: 0 Saves: 0. See Prices
Oct 29, 2015 | Kenmore Quiet Comfort 12 Humidifier Filter...
Have a new evaporator to install, and directions on box say to "1. Note Humidifier Control setting and turn dial to "OFF" position." ... however, there is no dial, at least, not on the...
They are talking about the Humidistat which is separate to the Humidifier. Turn the power off to the furnace and that will disconnect any power to the humidifier. Turn the water off to the Humidifier if you have to remove it from the plentum. Then go ahead and install your new evaporator. If you are looking for the humistat follow the T-stat wire and see where it goes from the water valve of the humidifier...... But they may not have installed one and are useing a different way to turn the Humidifier on in the heating cycle.....
Feb 01, 2011 | Aprilaire 550 Humidifier
I have a carrier humidifier model BG49. When the furnace turns off due to reaching room temp. The water still continues to flow into the reservoir of the humidifier. Is this the correct operating...
Hello, The humidifier should turn on and off with the furnace's blower motor, If the humidifier keeps continously running than the solenoid valve is stuck open and should be replaced.
Jan 30, 2011 | Carrier LFP Humidifier
Is the humidifier supposed to turn on when the furnace does. Does it turn on more often when the temperature outside is higher.
Hello, Yes the humidifier should turn on when the blower motor on your furnace kicks on, this way you are only using water and power when the furnace is on instead of wasting it when when the furnace is off. Regardless of outside temperature the humidifier will only turn on and off with your furnace.
Jan 21, 2011 | Aprilaire 700 Humidifier
The humidifier says "desired humidity" when turned
I would say, either the humidity level in the room is hi or the humidifier is defective, In my house the humidity is about 42% to 45% when we use the humidifier, and can drop to 30% or less if we don't, we leave in DC area,
I hope this helps.
Jan 14, 2011 | Vicks V4500 1 Gallon Humidifier
No water going to furnace humidifier
The furnace should be equipped with a #50 relay to turn the Humidifier on and off when only when the furnace blower is on. You should have a test mode on your humidistat. Do you have water coming up to the solenoid valve? Make sure that the saddle valve is turned on to supply the water to the humidifier. Is your humidistat set high enough to turn the humidifier on? Is it plugged in?
Good luch
HVAC Teacher
Mar 04, 2009 | AutoFlo 400BP Humidifier
Reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Jan 03, 2009 | Holmes Products Halls HLS5000-U Humidifier
Honeywell 360a humidifier
yes water should turn off solinoid is bad
Oct 24, 2008 | Honeywell HE360A1027 Whole House...
HM5081TG Reset Light won't turn off
Reset the unit once it is refilled by pushing the power button and holding it down for 5 seconds before releasing. This should reset your unit to factory settings.
Oct 21, 2007 | Holmes Products HM5080-U2 Humidifier
Humidifiers Logo
44 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
