Does not turn on
Plug in no display or power
    Top Expert:
  • Computers & ... Master
  • 26,177 Answers
Power unit faulty, power button faulty. Without a clue as to what it is, we can't really help much.
Posted on Dec 19, 2016
Hi there I have got a toshiba satellite c50d-b-120 laptop and the other day I turned it off then in the morning I woke up and tried to turn it on but won't start need help asap
Verify the power adapter is working with multimeter. Should display 19.5v
Drain capacitors - Remove power plug and battery from laptop. Hold power button down for 30 seconds. Put battery back in and plug in. Try to turn it on.
If it turns on but you are getting no display, plug in an external monitor to see if it's a display issue
Jan 25, 2016 | Toshiba Computers & Internet
My amino notebook pa 3553 can turn on but no display nothin comes when u turn on
Hello!
Please turn off power.
Please unplug from power.
Remove battery.
Plug in power.
Turn on power.
If computer works please replace and dispose of battery promptly and properly.
DANGER: Many batteries are fire hazards!!!
Best Buy (Zambia, Tanzania) has a recycle program.
Please return to share results.
Thanks!
Jimm
Nov 20, 2012 | Computers & Internet
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
I cleaned the pump filter after getting sud error. now i get F 21 code.
Press the pause cancel button 2 times this should clear it. If it does not and the filter and drain hose are clear you will need to replace the pump.
F21 Fault Code Repair
LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:
After 4 minutes the "Sd" error will be displayed, then 4 minutes later the "F/21" error code will be displayed.
Press PAUSE/CANCEL two times to clear the display.
LONG DRAIN
NOTES:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
LONG DRAIN
NOTES:
Nov 03, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Tower turns on but nothing appears on monitor
You need to follow the easy steps and get rid of it
1. Make sure your display (moniter, CRT, LCD, screen, whatever you prefer to call it) is plugged into a wall outlet or power strip and powered on. Also ensure that it is securely plugged into the back or bottom of your display. Many displays do not have removable power cords, making them more prone to shorts and other damage. Check your cable to make sure it isn't damaged.
2. Make sure the power strip or wall outlet that your display is plugged into are functioning by plugging another electrical device, such as a lamp, into it and switching it on.
3. Check the connection between your computer and your display. Make sure that it is completely plugged into both as well as fastened with the attached screws.
5. To double-check any possible cable problems, if at all possible, swap out the screen's power cord and the cable connecting your computer to your display.
6. Swapping out your display is also a good way of narrowing down the problem. If you get the same result with a different display, then you can be near positive the problem is something in your computer. If switching displays fixes it, then the culprit is a faulty display.
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the monitor but in the computer.
Read more: http://www.brighthub.com/computing/hardware/articles/12648.aspx#ixzz0s9UQmWub
Please rate me if this solution works for you
Thanks......Have a great time
Jun 26, 2010 | Gateway 504GR PC Desktop
Describe your Epson im- 700 pos machine com portProblem Hi, We have IM -700 POS now its getting problem with printer and display. Showing com port error code 1001 pls any body can help
If you are getting display problem then
7. Try turning your display on and off. Does the power indicator light change? Green means On, amber means Standby, and no light means no power. If your display starts out green when it is turned on, then goes to amber, that usually means that it is not receiving any signal from your computer and therefore assumes it is not needed. The problem is most likely not with the moniter but in the computer
May 18, 2010 | Epson POS TMT88IV Thermal Receipt Printer
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
My c7180 keeps coming up error OXC18a0201 Ink system has failed, it says to shut off, and I have and it comes right back
Problem occurs for me when i run too long with an empty cartridge solution press * and # at the same time press 1 2 3 and "support R0632M" should display press > and "information menu" should display press > and "configuration menu" should display pres OK and "hardware failure status" should display press OK "failure status:clear" Press OK to clear press cancel press cancel press cancel turn printer off unplug power cord for two minutes plug back in power on use your printer
Jun 28, 2009 | HP Photosmart C7180 All-In-One InkJet...
Computer won't turn on
check your monitor connection and memory ram
Jan 06, 2009 | HP Compaq Presario SR1420nx...
Power Problem
power down only apply if you power down button put the hold 5 second printer automatic power down after that u unhold
Feb 26, 2008 | HP PSC 1610 All-In-One InkJet Printer
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
